top flite sea fury
19 Mar 2013 15:40 #46 by alan cantwell
Replied by alan cantwell on topic top flite sea fury
Cowls looking---better, with the flaps, to couple 2 together that want to go away from each other, 2 blocks, hole drilled in, piece of 3 speed bike cable, or a cranked piece on piano wire, glue one side in, the other side is not glued
19 Mar 2013 16:13 #47 by Ex-Member
Replied by Ex-Member on topic top flite sea fury
what i did was glue a bit of snake inner across the gap between the flaps.
held it in place with some blocks.
then cut it in half through the joint.
ran a bit of cranked piano wire through the snake and glued one end solid.
so one flap is working now, will tackle the other one tomorrow (maybe)
cowl still needs work, but it is getting there.
19 Mar 2013 16:28 #48 by alan cantwell
Your welcome, :whistle:
20 Mar 2013 15:37 #49 by Ex-Member
not got much one today been gardening. :(
second split flap is joined and drying.
cut a bit more litho plate.
sorting out the battery hatch and tail wheel doors.
then took a look at the arrester hook.
thats all folks.
21 Mar 2013 19:30 #50 by Ex-Member
been gardening yet again and had to clean the drain out. :sick: :sick: :sick:
so not much to report.
the second split flap is done.
still debating about the u/c, will have to see how funds go |( the money i had in pay pal ended up paying the phone bill :( )
26 Mar 2013 17:02 #51 by Ex-Member
cant raise any enthusiasm at the moment.
thats it. :(
27 Mar 2013 17:43 #52 by Ex-Member
took the cowl off today and started covering it.
should be ready for paint tomorrow.
need to look at the intakes along the wing tomorrow as well.
28 Mar 2013 17:51 #53 by Ex-Member
slopped a bit of paint on the nose.
30 Mar 2013 16:03 #54 by Ex-Member
i am standing by to get my bum kicked, but i have fitted temporary fixed u/c to the sea fury.
the mounts are set up to take electric retracts at a later date and the legs will fit in retract units as well.
made a start on the intakes along the le of the wing.
not fully to scale (i have decided that i cant do scale without plans, as my scratch building skills are not good enough) but its the best i can do at the moment.
31 Mar 2013 14:39 #55 by alan cantwell
Why should you get your ass kicked? fixed legs while you save for retracts later on is a great idea, in the YT kits, hardwood blocks, the same shape and size as the retract blocks are supplied in the kit, cowls looking good, by the way, arnt you glad now i didnt blow sunshine up your ass and just shoot praise at you ???? this will be a fine model, keep the thing, and FLY it
01 Apr 2013 01:20 #56 by Sarah-Jane Smith
Replied by Sarah-Jane Smith on topic top flite sea fury
That is beautiful Tony
02 Apr 2013 16:20 #57 by Ex-Member
Again not much to report.
done some more to the wing intakes, the undersides are ready for sanding, still got the tops to do.
sorted the battery hatch.
sorry. :( :( :(
02 Apr 2013 20:44 #58 by Eric
Replied by Eric on topic top flite sea fury
What are you apologizing for, Tony?
I have got as far as putting the prop onto the Decathlon!
03 Apr 2013 17:55 #59 by Ex-Member
well between work for swmbo i did get a little bit done.
started constructing the dash.
looked at the seat.
started lining the cockpit.
The dash is not right i know, but i have not worked out how to do black dial on a black surface yet.
have painted the inside in green and once dry i can fit the dash, seat and take a look at the floor.
04 Apr 2013 13:01 #60 by Ex-Member
Seat and floor in now.
started the controls, not doing any more now. i think this is scale enough for me.
back later.
Time to create page: 1.199 seconds
