Fi 103 - the other V weapon
It is interesting to note that the engine cut out before it hit the ground was not intended but simply a result if the fuel feed to the pulse jet was unable to handle the negative g as the elevator was put full down.
It was not clear if or when the Germans knew it was happening but it certainly added to the terror effect.
Fuel consumption was rather erratic and could not be accurately checked beforehand as the pulse jet shutters only had a very limited life before its vanes started to fatigue and fracture.
The Ford spent some effort trying to improve the shutter life on the American version (JB-2 Loon) in an attempt to increase its range but only extended the average life by a few minutes regardless of the material used.
On the Natter I used 'ring' formers cut out of 3mm Depron. It worked well enough but the formers are relatively weak so the fuselage can be fairly easily crushed by a point load, typically your fingers holding it for launch or a tuft of grass during a belly landing. Solid formers would better resist crushing but would contain 3 or 4 times the material.
On the V1 fuselage the ring formers are thinner (2mm Depron) but the inner edge is reinforced with a 9mm wide flange. In conjunction with the skin each former becomes a circular 'I' beam.
The 6 formers of the 13" centre section.
The disks cut out of the centres are large enough to be used as some of the nose and tail section formers.
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
From the inside it looks more a bit of the hull of a nuclear submarine. :ohmy:
The next sections will have much more taper so the fuselage will be made up of 4 pieces as well as a solid nose and tail cone.
In this way the required taper of each plank is reduced so reducing the cutting waste.
- Sarah-Jane Smith
- Gone
The lower 2mm Depron skin and the 'spindled' hard balsa spar.
The complete tailplane with elevators in position.
The elevators have a fully shrouded hinge line.
Operated by a single 5g servo in the fuselage tail section.
