Auster mk5
i got the plans out and decided that 72" is not big enough.
soooooooooooooooooooooooooooooooooooooooooooooooooo
i am drawing up some plans that are 25% larger, that will give me a 90" wingspan and more room for detail.
want to have opening doors on this one.
i will need to split the wing for transporting, so do i do a 2 piece wing or 3 piece with a fixed center section.
hmmmmmmmmmmmmm and need to work out the best way of joining the sections with the minimum of fuss.
it is interesting work doing a design.
how was the original fitted.??
- Phil Wood
It looks like you have a fuselage brace right across the door opening. :ohmy:
Now if the brace went across the other diagonal.....
it's when you sit back and look that you notice little things like that.
at the moment i am just enlarging the original plans and will have to alter things to get the look i am after.
the tail is 1/4 sheet, but in will want to make it a built up one with fabric covering.
the fuselage is sheeted with stringers on the outside to replicate the fabric covering, so i will cut holes in the sheet to lighten the rear end.
then once i have cleaned up the pencil lines i can look at working out all the details;- like how to work the door, battery hatch, servo placement,wing fixing and endless other bits and bobs.
i might even start cutting some ply formers, maybe.
still waiting for glue so everything else is on hold........
Auster
Surely this is one case where a conventional balsa 'framework' type construction would be scale.
don't know if i want to completely re design the thing or just mod what has been done.
might just do it the (sorry Garry) way they designed it but cut some holes in the sheet sides to lighten it.
anyway i mucked up the fin drawing. grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
have to re do it later.
- Thank you received: 10842
then i do it again in ink and make a mistake i can't rub out. humpf........
OH POOOOOOOOO just had a look at the frame work pic and all the ribs in the fin and rudder are wrong, got too many.
need to re draw it all. sugar sugar sugar.
fuselage plan is wrong as well.
time to screw it all up and start again. humpf
i might have bitten off a bit too much with this one. :blink:
still we can only try.
