Auster mk5
24 Jan 2014 18:41 #256 by alan cantwell
Replied by alan cantwell on topic Auster mk5
24 Jan 2014 19:35 #257 by Ex-Member
thank you Alan.
need to work out how to make it now.
24 Jan 2014 19:44 #258 by old fart
Replied by old fart on topic Auster mk5
I'm sure you'll work that one out as speedy as you do your building.
24 Jan 2014 21:13 - 24 Jan 2014 21:21 #259 by Eric
Replied by Eric on topic Auster mk5
Would this work, Tony? You'll need to play about with dimensions, to get it sliding freely without slop.
Something similar was made commercially, but I've not seen it for a long time.
ps - I missed off that the two ellipses are slots, one up and down in the fixed portion, and one angled in the slider.
Last edit: 24 Jan 2014 21:21 by Eric. Reason: added a comment
Thanks: Klipkopwildlife, Ex-Member, Sarah-Jane Smith
24 Jan 2014 21:50 #260 by alan cantwell
Thems will be DB models swingees
25 Jan 2014 11:56 #261 by Ex-Member
found these on line.
hinges
will they be any good.
25 Jan 2014 12:27 #262 by Eric
Kavan used to be good kit. They look like a better engineered version of my sketch, only using an assymetric hinge-line for the rotational conversion.
25 Jan 2014 13:22 #263 by Quorneng
Tony
The only problem is those types of hinge work at a low mechanical advantage so there is comparatively little rod movement thus requiring high forces from the servo.
25 Jan 2014 15:48 #264 by Ex-Member
well i have ordered a set to see what they are like.
if they are ok, i will use them for the flaps and then have a re think about the ailerons.
started making the ailerons today, but not got very far with them. :(
25 Jan 2014 19:09 #265 by Ex-Member
well the first design was not very successful, too flimsy.
building them scale was not going to work.
so i went back to the old method.
solid sheet center section with half ribs.
wont be seen when covered will it.
26 Jan 2014 13:16 #266 by Ex-Member
the ailerons under construction.
26 Jan 2014 18:09 #267 by Ex-Member
well the ailerons are made now, i need to shape the leading edges and then hinge them ready for fitting.
got to wait and see if these hinge horns i ordered are any good before i can go any further with them.
27 Jan 2014 15:41 #268 by Ex-Member
well, hmmmmmmmmmmmmmmmmmmmm.
spent an age bending wire to make the roof wires, not sure if they are right though.
they look fairly close to the pics i have, i take it the plastic roof panel does not touch them.
if they are ok, i will glue them in tomorrow ans then solder thee center together.
will have to make the trim tab winder to got there as well.
remind me next time to build something less complicated. ;)
27 Jan 2014 16:15 #269 by Ex-Member
want to look at the cabin inner uprights tomorrow.
i plan to run wire down each upright from the wing rods down under the floor to give some more strength to the cabin area.
then we have the rear wire supports and the front glazing bars.
once all this lot is done the whole cabin area will be massively stronger than it is now, though i cant pull the wing supports off the fuselage at the moment anyway.
the glazing will be fun, lots of curved plastic needs to be formed.
28 Jan 2014 12:29 #270 by Ex-Member
for the naggers out there. (you know who you are) :P
luggage.
can i get on with something else now. :)
Time to create page: 1.364 seconds
