hawker sea hawk
What size is the EDF?
1000 watts
1.73kg thrust.
64 amps.
might be enough.
might be enough.
Should be but much is going to depend on the effect that bifurcated ducting has on the performance of the fan.
wings are on an i need to design and draw up the fairings next.
now comes the fun part of designing the wing fairings, now if it was just for me i would bodge something together.
but as it will have a plan, i need to design a set that can be easily built by others.
thinking cap has been put on.
fin skinned.
next i can finish sheeting the fuselage and we are ready for sanding and covering, then paint and canopy.
I am sure that composite plate will be remarkably strong but I am not quite sure why you need it.
With Depron even a modest crash will cause damage to the airframe so does it actually matter if the LiPo battery box breaks up?
Depron itself is too soft to puncture a LiPo.
plus it will give a little more strength to the nose area.
elevators are made and covered
ailerons are made and partially covered
that's it for today.
Are you at the point where you could fire up the EDF with the Sea Hawk nose down on some scales to measure the thrust?
