could be mistaken for the full size.
well done
- Septic
- Thank you received: 690
Fingers crossed the extra 10g of paint and detail doesn't upset the flying too much.
tap - tap.......rivet
- martynk
- Premium Member
Martyn
Martyn
- Septic
Nah doesn't look like Dad, that would be kind of fun to get one made from a pic though
- Septic
- Septic
the procedure of fitting the wings are to hold the wing against the centre sections and slide the retaining wire through the two 1/16 Glass board lugs on the wings and the two lugs attached to the centre section, from front to rear. This locks the wings laterally to the fuselage.
The wing struts then set the dihedral and take the flying and landing loads. The struts are attached in a very specific sequence and are retained simply by tension in the setup. The first step is to slide the forward strut anchorage through the wing tab and rotate through 90 degrees. The attachment alongside requires the struts to be sprung lightly apart befor sliding the strut end through its corresponding plate. The two riser struts are sprung apart and fit into their two corresonding tabs. This makes for a rigid assembly, with the final remaining tab on the fuselage is slightly forward of the apex of the wing struts. This needs the struts to be sprung forward to fit. The tension to spring back holds it all together and the wing cannot move. Very simple but aleviates any need for clips etc to hold the wings on. On a hard landing the tabs pull out of the fus and are easily glued back in again. It sounds fiddly but the wings come off fairly easily.
Hopefully pictures may help explain?
Hope this is what you meant?
Oh I used the location of these tabs on the plan to make the stencils, so I could use them to allign the stencil
Cheers
Danny
- Septic
Cheers
Danny
- boz
- Thank you received: 1420
- Monz
Hope today went well at Shawbury. Pics and vids please, or it didn't happen
- Septic
The flight did not go to plan, the yellow dope finish had gotten into the thread hinges and they were not as free as they were, so centring was vague. I should have remembered that we threaded hinges AFTER painting. An easy fix. The stiff hinges and slightly rearward c of g from the paint meant a very hairy flight, which ended with a bumpy landing. One wing tab loosened and the blessed cowl knocked loose again. Anyway that curtailed further testing. It did however prove that the model can turn tight in both left and right hand circuits, one observer couldn't believe how well it turned with scale dihedral of almost zero! But it does.
Anyway a few repairs and then its back to Shawbury in a month. The extra weight didn't have any effect on the models lovely slow speed I am pleased to say
Cheers
Danny
Your comment on the extra weight of the paint not seeming to affect the model's flying speed is interesting and set me to thinking.... Weight is against us in the model world on several counts. The lift on a model is proportional to the square of the speed, which means that if we double the speed, then the lift increases by a factor of four. Conversely, and since for level flight lift must equal weight, if we double the weight of the model, the flying speed goes up only by the square root of 2, i.e. a factor of only 1.4. I'm not sure what the weight increase is on your model, but lets say it's 15%. That would equate to an increase in flying speed of only 7%, which is not really noticeable.
Now, considering the rearward C of G. That makes the model fly with less up elevator, which means less trim drag and therefore, less required thrust. But, it also means that there is less down force on the tailplane, and therefore, the wing needs to provide less overall lift. This reduces the required flying speed slightly.
Putting the above two together would explain why you didn't notice a change of speed.
Now, when you get the C of G in the right position by adding weight to the nose.....you may then see a difference!
