A W Ensign
And in those days you didn't need a set of 'air stairs' to get on board - no higher off the ground than a horse drawn carriage!
four 300watt brushless motors.
so i have to be able to keep it under 12lb when finished.
fingers crossed.
will be interesting.
thinking of balsa stringers round the window sections to add some strength.
ones side of the fuselage all cut and ready for assembly.
the other side will be different as some of the formers will be altered to allow for corridors and toilets.
i am having two 3mm Depron cores and will build the fuselage in two halves, only joining them together once fully sheeted and fitted out.
makes running wires and fitting out the cabins easier than trying to do it to a one piece fuselage.
windows need to be designed next.
these are cut from 3mm White Depron and glued to a 6x3mm balsa frame.
the frames are then glued into the relative formers.
i plan to sheet the whole fuselage in white depron and will then line the inside of the windows with clear acetate.
still waiting for the varsity bits to turn up.
Today i made up 27 seats for the passengers.
Then i had the fun job of starting to fit the floors.
these have to be angled so that they are level when the plane flies and as it flies nose down it is not easy.
still i have some fitted, will do more tomorrow...i hope.
cos all i can find are black and white pictures.
Owner proprietor of B.E.A.
Bennett's Electric Aircraft
From a 1957 Flight Global article describing the history of the Ensign
"Furnishing was designed by L.A. Rumbold & Co Ltd and the interior finished through out in green and cream upholstery."
This is a still from a movie showing the inside of an Ensign which seems to suggest the seats were all cream with some of the panelling green.
This site has nice detailed drawings of the interior.
