- Thank you received: 1420
Beware Revolver and lipos
- boz
28 Feb 2018 06:04 #16
by boz
Replied by boz on topic Beware Revolver and lipos
Ammo boxes sounds like a good idea
, the bag I bought was about £6 if I recall, they do take up less space, but I did not know they were no good after use.
28 Feb 2018 09:24 #17
Replied by Eric on topic Beware Revolver and lipos
It looks like the lipo was about burned out when BB extracted it, and only one cell went up.
They don't burn for very long, but they DO burn very fiercely, like a magnesium flare.
03 Mar 2018 10:40 #18
Replied by Klipkopwildlife on topic Beware Revolver and lipos
You remark that you charges you last 2 Turnigy Lipos 'the whole day' This doesn't ring right for me, I plug my Lipos into the charger, tell the charger what size it is, press go (enter) and some time later the charger bleeps and the charging is finished. For a 2200mAh out of the Funcub it's about 45mins.
Another thing, if any Lipo is under a certain minimum voltage the charger will refuse to charge it, saying 'connection break'. A 3 cell Lipo can often be recovered by putting it on a Pb charge for a few minutes, just enough to lift the voltage above the minimum, whatever that may be, and then switching back to 3s Lipo charge.
- Thank you received: 10842
03 Mar 2018 12:08 - 03 Mar 2018 12:09 #19
Replied by THE BLACKBIRD on topic Beware Revolver and lipos
NoNo i do everything you do mate, put the information into the charger connect up both power and balance and when its done it bleeps and switches itself off charge giving a flashing full sign, which it did last night on the one thats dead this morning. like i said its a top of the range charger from turnigy
or its suppose to be
Last edit: 03 Mar 2018 12:09 by THE BLACKBIRD.
03 Mar 2018 12:57 #20
Then I would definitely say it's your charger that's giving you grief, best bin it. I have an iMax which works well, only one at a time though. My other charger is the one that came with my Nemo, only charges through the balance lead, 2s or 3s, but doesn't take much longer than the iMax.
03 Mar 2018 16:11 #21
by The Beard
Replied by The Beard on topic Beware Revolver and lipos
BB i think you did a great job as ive seen lipos in action and they carry on underwater
- Flytilbroke
- Thank you received: 1987
05 Mar 2018 10:21 #22
by Flytilbroke
Replied by Flytilbroke on topic Beware Revolver and lipos
Certainly did no harm and seems to have helped in your case. I have seen where Nitrogen and Foam extinguishers did not work tho'. Pleased for you result.
05 Mar 2018 13:50 #23
I see there's a very good article on Lipos' in February RCM&E
Time to create page: 1.992 seconds
