Day job
Eric
Offline
Moderator
Eric
Re: Day job
Yesterday 06:48 - Yesterday 07:04
I have yet to ride mine! (and it is MINUS 2C at the moment!)
Tyre pressures, 30 lb is about right for a fat-tyre. It should be embossed on the side-wall, just like on a car tyre. If not, and it isn't mentioned in the instructions, see what's in the BACK tyre, and put the same in the front. Fat-tyres DO have more rolling resistance than a skinny racer-style wheel and tyre.
Have a look at
wheelsforwellbeing.org.uk/
and see if there's a group near you. Maybe they can help.
You say your shoulders ache - perhaps you have the seat too high, or the bars too low, so you are leaning forward with your weight on your arms?
Daft question - how long ago was it that you last rode a bike? For me, it was about 20 years, on a 21 gear mountain bike. I went about 10 miles, and gave myself a sore arse!
Have a look at
Last edit: Yesterday 07:04 by Eric. Reason: added a comment
THE BLACKBIRD
Offline
Forum Master
THE BLACKBIRD
Re: Day job
Yesterday 09:11
Ha Ha the seats not not that comfortable and iv got it as far down as it will go, i think the riding position is about right, the pain is in the shoulder with the knackard joint
Thanks: Klipkopwildlife, SimonC
Flytilbroke
Offline
Platinum Member
Flytilbroke
Not Tired, long retired "Bob"
Re: Day job
Yesterday 12:02
Did a Search on't Internet.
For 4-inch fat tyres on an electric bike, a typical starting pressure is 12 to 20 PSI (0.8 to 1.4 bar) on pavement or hardpack, dropping to 5 to 12 PSI (0.3 to 0.8 bar) for loose dirt, mud, snow, or sand—always staying within the range printed on your tyre sidewall
Klipkopwildlife
Offline
Re: Day job
Yesterday 13:43
Certainly sounds like too much pressure, it's not letting the tyre construction do its stuff.
THE BLACKBIRD
Offline
Forum Master
THE BLACKBIRD
Re: Day job
Yesterday 15:49
Hi Tony you seem to have been missing for a while
Today iv put a new top on the bench ready for the new build, just a sheet of plasterboard, the old top i cut down and laid it on the shelf under the bench
I cut a 250mm wide strip off the new plasterboard and made it into a bench 2m long 250mm wide to build the new fuselage on
Thanks: Eric, Flytilbroke, jon.in.swansea, SimonC
Eric
Offline
Moderator
Eric
Re: Day job
Yesterday 15:56
The pressure range embossed on my tyres are - Minimum 25 psi. Max 45,psi.
So mid-range is 35.
and a thought on BB's lack of stability. If he's never ridden a small wheel bike, only a big-wheel - 26" or so, the smaller wheel will have less gyroscopic stability - hence his oversteering and wobbling.
So mid-range is 35.
Thanks: THE BLACKBIRD, jon.in.swansea
S
SimonC
Offline
Premium Member
SimonC
Re: Day job
Yesterday 16:43
I have to agree with Eric. Balance on small wheel bike's is different but the way you see youths driving electric scooters on the pavement they probably don't feel any balance difference.
I have certainly noticed my balance certainly ain't what it was! I used to be able to stand on one leg as long as I wanted to and be able to do something else at the same time, like putting on a pair of trousers. Not so much now at 80!
When I drove an electric "stand on" scooter down the road last year I really struggled to keep it straight.
As a teenager I rode a bike to school every day and could annoy my younger sister by riding her pedal trike on just two of its wheels with the inner wheel hanging over our circular pond.
Back then balance was a problem.
Just saying.
Just saying.
Thanks: Eric, Flytilbroke, THE BLACKBIRD
Time to create page: 0.458 seconds
