Weston UK Cap 232 Build Blog
Tony B wrote: or just buy new and be done with it.
That would be my preference
Sorry, I meant Tom, perhaps just 5 minutes then!Tom T wrote: Thank you Beard, I will certainly give it my best shot. Once I have located and bought some covering I'll do some experimenting before covering. Should be a lot of fun if nothing else!
I have been offered these, they are £15 for the lot of them, views please..
The Beard wrote: Never had a problem with Futaba servos whatever vintage and new ones often sound rougher.
Maybe because they're new, i,e, new and tighter geard and bearings etc.
- Tom T
- Thank you received: 91
(Sorry I haven't commented earlier, been busy
- bogbeagle
- Senior Member
- Thank you received: 119
- Flytilbroke
- Thank you received: 1987
but i did find that the covering had bubbled where it was sat on the bench in the sun, re shrunk it.
hope this is not going to keep happening.
servo's turned up today, so if i am allowed in the shed tomorrow, i might try to finish the fitting out.
whoops, I know that situation so well!Tony B wrote: so if i am allowed in the shed tomorrow, i might try to finish the fitting out.
rudder and elevators fitted, hinges all pinned as well.
the twin elevator servo's are in and all connected up.
got a problem with the pull pull set up for the rudder, the wires are not long enough to enable me to get the servo on the cog point, so i will need sort out some fishing trace wire at the weekend to re do it.
Tail wheel is fitted.
wing bandage is now setting and then i can sort the ailerons and cover the main wing.
spats are fitted and drying.
been a long day with not a lot to show for it, this is the reason i hate fitting out, takes ages to do very little.
hence i have loads of models at this point and then forgotten about.
not a lot i expect.
u/c is back on.
pull pull on the rudder is sorted and working.
motor is mounted
cowl is on.
canopy is trimmed a bit more.
slopped a bit of paint about.
need a second coat on the cowl.
the wing bandage has set fine, so i can do the aileron servo's later and then cover the wing.
got to sort out a battery tray and fit the esc and rx, job done.
