- Thank you received: 91
Weston UK Cap 232 Build Blog
- Tom T
ready to start covering tomorrow.
colour is using what i had left over. ha ha ha
mind you it is going to be a hack so how far do i go with decoration.
also fitted the hinges into the ailerons, pinned them as well to be safe.
tomorrow i can fit the ailerons to the wing and connect everything up.
then fit the battery tray and see about c of g.
that will be it then, unless i do any writing on the fuse and wings.
sponge fingers most definitely.
pinned the aileron hinges, fitted the control horns, made up the connecting rods.
ailerons work ok.
put a battery in the nose, put the wings on, measured the c of g and marked it on the fuselage.
picked up the plane and put it on the balance points.
tail heavy.
no probs , lets add some weight.
2.5lbs :blink: :blink: :blink: later it was balancing.
ouch a bit much me thinks.
takes it to just over 11lbs which means i cant fly it at my club without a "B" cert.
so it is a hmmmmmmmmmmmmmmmmm moment.
now there are 2 full size servos in the tail for the elevators, sooooooooooooooooo if i move them up the front and put them on the c of g point, then run 2 snakes down to work the eleavtors.
i should save a bit of nose weight.
still going to be a very heavy plane, not sure if i will be able to fly it.
the 25cc engine would weigh 2.5lbs over the 1.5lbs of electric motor and battery.
i am going to take the elevator servos out tomorrow and just drop them in the fuse in front of the c of g mark and then see how much weight is needed in the nose.
if it is still tons, i will strip all the electrics out, assemble it all and put it on ebay.
get some money out of it.
shame though.
need to weigh the sea fury and see if the motor i have will be powerful enough.
