Blackhorse CAP 232 180
- Thank you received: 10844
But i have been playing with it again nearly al lmorning at home so tomorrow i try again, i think i have it right this time
I even got to taking one of the engine bolts out to change it to ELECTRIC then changed my mind .
I WILL WIN.
So i ran it on the ground and finnished up after an hour or so with it tethered to a post running flat out for long spells then ticking over then full power again until i had used the full tank of fuel.
Its mended now waiting for tomorrow morning, so keep them crossed
Landed and the propeler and spinner had gone the prop nut was still there ??? a little damage to the cowl.
So thats it a new petrol engine or electric i dont have either at the moment.
- Away
- Thank you received: 14474
Will the engine still turn over, with another prop on it?
- Phil Wood
Not until after the Nat's BB .... we can talk about all these problems at length there & get them sorted.THE BLACKBIRD wrote: The engine is out of the plane it still turns over ok, now i have thrown the thing in the shed along with the planes I'm p***** off with it all, going back to modelling trains.
:huh:
- Grumpy42
Read your post Grumpy and have put some tempory internal ducting as you said and opened the air outlet although it was big i had looked at it before and decided it was ok
- Phil Wood
Thanks Grumpy for the input, next time stick your nose in sooner
- Grumpy42
THE BLACKBIRD wrote: I win got the cap flying ok this morning, the air ducts work, i also fitted a larger bore fuel pipe, i had it for the turbine its for petrol not glow so ill have to change it this week, but the two improvements worked, i had to turn the needle valve in quite a few turns and it was still running rich, the second flight turned it in a few more turns and bingo it went very well.
Thanks Grumpy for the input, next time stick your nose in sooner![]()
Glad I could help BB - the Moki really is a nice motor AND being the modest Colonial Gentleman that I am I won't even stick it up Garry - BUT - it is sooooo tempting.
- Away
