Blackhorse CAP 232 180
- Thank you received: 14474
- Phil Wood
Can't be certain without doing a lot of thermodynamic calculations Eric, but I'm fairly sure petrol will burn slower.Eric wrote: One for the scientists - does methanol vapour under pressure burn faster or slower than petrol vapour under pressure?
Petrol contains additives to make it burn slower .... this used to be in the form of lead compounds.
They do this so that the pistons in car engines get a slow continuous push down the bore rather than a sudden clout at the top of the stroke.
Edit .... This post is wrong .... I've corrected myself a few posts down.
- Phil Wood
You could be correct Klippy, I'm just guessing that petrol is deliberately slowed down .... I suppose the different compression ratio and ignition timing might be down to a different ignition temperature, flash point or fire point ....Klipkopwildlife wrote: I'm under correction here, but Petrol engines generally need less compression than Methanol, one of the things you have to do when converting is reduce the Compression ratio. When converting cars to run on Meth you generally have to give it masses of extra advance which would mean that Meth burns slower.
en.wikipedia.org/wiki/Flash_point
If I can find the time I'll look into it further.
- Phil Wood
"Methanol is far more difficult to ignite than gasoline and burns about 60% slower"
en.wikipedia.org/wiki/Methanol_fuel
- Thank you received: 10844
But cannot find a APC prop that size, anybody know where i can get them
I did another range check and everything seemed ok so i flew it , no problems im pleased to say
But a bit off putting after all thats gone on
