- Thank you received: 10844
Blackhorse CAP 232 180
I will put plastic ones with the metal pin in them,
- Grumpy42
THE BLACKBIRD wrote: The thing that worries me is that the Sprint has tape hinges as well and it is a 150 mph plane but i have been assured it is fine with then :ohmy:
still if i have nowhere to fly the bugger it will not matter.
Even if it is not going to fly in the immediate future, I would change them. Otherwise, sods law will kick in and when it does fly you will have forgotten about them until the crash. Dont forget what can go wrong , will.
- Thank you received: 14470
A bit of head scratching and i found some litho plate not as thick but i cut two new gaskets fitted them and it runs again ok.
Ill go flying tomorrow and see if it holds together.
- Grumpy42
It went straight in nose first even snapped the 1-1/2" alloy tube that holds the wings on.
And i managed to crash my glider as well, this was my fault not checking the controls, i launched it ,it powered away i gave it some up elevator and it dived into the ground f
g idiot.
A lesson for Sarah check everything before you fly.
Very p*****d off
Or, of course, it might not be a perfect seal, so is leaking.
Took one of the litho plate head gaskets out of the moki 180 will see if it gives more power.
I have found a new gasket in the uk but it takes so long to get anything sent here.
Had a couple of cans of John Smiths tonight so i can use the cans to make new internal ducting for the motor now i know it works
I found a tube this morning thats a dead fit inside the ariginal tube, so at least i can fly untill the new ones come through.
