D.P.R Rare Bird Sailplane
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
Klipkopwildlife wrote: Just looking at the wood and the construction I'd say this bird is going to be quite heavy, in terms of oz/sq ft.
I have no idea but reckon after a few bits fall off on its first flight it will weigh a lot less :lol:
Try to work out the high and low stress areas of the model. For example, the wing roots will take the stress of holding the model in the air and up the launch. The tailplane ribs are at the back and need to be light to save on nose weight.
The balsa in a kit will be variable in both weight and stiffness. Lets take the strip wood as an example. Taking all the strip of a similar size, either weigh each piece or make up a rudimentary balance and weigh each piece relative to the others. You should end up with a line of strip balsa with the heaviest at one end and the lightest at the other. Mark the ends of the strip in some way to indicate their relative weight - i.e. 1 mark for the light strip, two marks for the medium and three marks for the heavy.
Then, line the strip up on the end of a table with most of it overlapping and see how far it droops. The less droop, the higher the stiffness. Mark the various grades in a similar way.
You can now choose the heaviest wood for the wing spars and main fuselage longerons, matching the stiffness on opposite sides of the model. Medium wood can be used for fuselage uprights and crosspieces and tailplane spars, and the lightest wood for tailplane and fin ribs.
- Sarah-Jane Smith
- Gone
Andy Sephton wrote: . I'll put some words and pictures in a thread I'll start on balsa characteristics, but in the meantime, for Sarah, I would suggest the following:
Brilliant idea,yes please- also can you include the reasons why other wood (such as plywood) may be used at certain points, eg my build has plywood used for the towhook
I would love to be able to say I am intelligent enough to work out what wood to use at certain stress points- but am not lol!! I followed the instructions which luckily enough stated when to test the wood and get the stronger piece of the bunch to use at certain points ( ie the harder 12.5mm x 2.25mm to use for the fuselage sides, use the harder strips for the fuselage top longerons, use the harder strips for the wing leading edges etc etc) Had it not stated to do this, admit I wouldn't have given it a thought :oops:
I tested for harder wood by very gently bending them and picking the ones with the most resistance. I was worried about warping the wood though so was ever so careful, however next time will defo use your methods, thank you
have been working on the wings, but was having one of those days yesterday when I kept getting parts wrong and having to reglue bits that kept popping out!! lol but both wings finished (pictures to follow)
I do have a question though regarding the wing ribs. The instructions did not state to glue each rib to the trailing edge, however they are kept in place here by the short spacers glued between each rib and to the trailing edge. My question is that with regards to the leading edge it only specifies to glue the first and last rib to the leading edge, thus leaving all other ribs NOT attached to the leading edge (hope this all makes sense lol)
Why is that?
I will also be interested in the answer to that! Seems odd to me.
- Sarah-Jane Smith
- Gone
Quorneng wrote: Hmmm
I will also be interested in the answer to that! See odd to me.
Have re read the instructions about 50 times lol, not once does it say to glue the rib ends to the leading edge. Unless I am reading it wrong?
Here is the exact instruction-
Pin a length of 9mm x 3mm shaped trailing edge in position, gluing to the rear of W1 and W10 (the first and last rib) Glue and pin a length of 6mm x 3mm strip upright across the front of W1 and W10 for the leading edge. Glue and pin ribs w2-w9 in position making sure these are upright and rest comfortable on the plan
Now, I read that later part to mean to glue in position to the top spar, which was introduced in the instruction prior to the above. Doesn't mention gluing to the leading edge though :pinch:
It seems odd to me too. I suspect what they want is for you to glue the LE to the root and tip ribs (W1 and W10) to set it's position, then when it says glue and pin ribs W2 - W9, it means glue them to what ever is available - i.e. to the LE, TE, spars, etc.
PS: you can also test balsa by digging a fingernail into it.....but such a thing is frowned upon by the purists.....and the model shop proprietors......so it wasn't me that told you.......
- Thank you received: 14473
W1 and 10 go in first, because tiny variations in the die-crunching can mean that if you are TOO precise in locating the ribs, they are either a fraction long, or a fraction short, for the marked space. So just ease them along a little bit until they fit properly.
p.s. Andy beat me to it by a second or so!
"Glue and pin ribs w2-w9 in position making sure these are upright and rest comfortable on the plan"
Apart from the dubious grammar I would definitely take the above sentance to mean glue them in everywhere they touch any part of the structure.
- Sarah-Jane Smith
- Gone
Really dreading this build finishing
Am very tempted to go get one of the cheapo Guilows kits from hobby craft just to give me something else to do, I know you said they were heavy Andy but nearest model shop is all the way over Warrington way and I think I really need to keep going
Sarah-Jane Smith wrote: Just repinned it to the board and gluing them in as we speak.
Cant agree with your logic Sarah, surly the nearest place is Alan 's house rather than going right to Warrington, or am I miles out?? He has more there than the model shop. He offered, so take him up on it
First one I saw was - www.modelshops.org/listing-details.php?shop_id=104
Don't know if it any good, or even still there. but it's only 'round the corner' from you!
Hmm! It might not be - just looked on google earth street view, and it shows an American Golf shop.
Try - Cheshire Model Supplies Ltd.
Address Reynolds Drive, Marple Bridge, Stockport, Cheshire, SK6 5QF
Tel. No. 0161 285 6348
E-mail sales@cheshiremodels.co.uk
Web Site www.cheshiremodels.co.uk
Shop Hours
G.E. street shows it's a bungalow, but it does say web only sales.
- Sarah-Jane Smith
- Gone
Eric wrote: Put - stockport model shops - into google!
It was there.....it is long gone though
Alan am coming to get youuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu :woohoo:
