- Thank you received: 10844
THE CYPRUS OWN DESIGN 2m x 2m F3A
Just making the plug for the hatch from blue foam then ill make a fibre glass mould and then hopefuly a fibre glass hatch
You can see where i have put filler in just below the canalizer,the wind got hold of it outside on the bench, i made a grab for it and fingers and thumb went straight through it, just the down side to working out side in the SUNSHINE
- Thank you received: 14470
First i used the ESC from the Revolver as it is the same size motor, just got it up to full power when snap crackle and pop it cought fire
Managed to yank it out without to much damage,
I then got the ESC that i saved from the SR 71 as it was the only one i had big enough, 160 AMP HV with the motor rated at 70
It got to 40 amp on the meter and bingo a big fire this time burning the model.
I think we can safly say that castle cremations ESC's are crap and if you have a decent model or any model for that mater leave them well alone
Still trying to get some sort of answer for the SR 71 fire from them
Anyway i have just glassed the cowl in the mould so will see if it will POP OUT
Tony the wheels are only useful on the ground so dont need to be big, less drag less weight
But i did change them for you
This is being built from sfuff i have under my bench, i do cheap nowdays, food on the table has to take priority
As Nat and her bloody son never stop eating :sick: :sick:
