THE CYPRUS OWN DESIGN 2m x 2m F3A
02 Jul 2014 20:39 #91 by Quorneng
Replied by Quorneng on topic THE CYPRUS OWN DESIGN 2m x 2m F3A
BB
Some glass cloth can actually be impregnated with an 'accelerator'. The resin dissolves it during the layup process so it goes off quicker. Your second coat would not have this advantage.
Are the dregs of the resin in your mixing pot also sticky?
02 Jul 2014 21:17 #92 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic THE CYPRUS OWN DESIGN 2m x 2m F3A
I will have a look at the mixing pots in the morning, there are several of them as i had maybe five small mixings to do it all
It went to the tacky stage quickly when i did it and just seems to have stayed there
04 Jul 2014 11:41 #93 by Eric
Replied by Eric on topic THE CYPRUS OWN DESIGN 2m x 2m F3A
Has that resin 'cured' yet, BB?
04 Jul 2014 14:42 #94 by THE BLACKBIRD
NO IT'S STILL TACKY :S :S :S
07 Jul 2014 19:52 - 07 Jul 2014 20:51 #95 by THE BLACKBIRD
The damn thing is still tacky so this morning i thought i would try some catalist on it, thought it might make it harden off, WRONG so i had to spend a couple of hours scraping it off :( :(
Then i was told to try a heat gun to activate it again, it made it worse so i stuck it in the fridge, at the end of the day im back to square one :evil: :evil: :evil
I thought i would make a riveting wheel for the lancaster as its ready for panel lines and rivets, made up a wheel bushed the axle equal spaced pins around the wheel ect ect, made a trough for the pva , took me ages, but would it hell as work, tried different mixes with the pva and water even tried some fairy liquid in it BUT NO RIVETS :angry: :angry: :angry:
Took some pictures of it all but they have not come out, Natalias bloody daughter has had my camera and buggerd all the setting up [badass] [badass]
Its day like this i wish i had stayed with the model rail roads
:S :S :S :S :S :S
Last edit: 07 Jul 2014 20:51 by .
07 Jul 2014 22:07 #96 by Eric
As I understand it, you need really thick pva that stays in dots where it is applied. Thinned pva just runs away.
12 Jul 2014 11:47 #97 by THE BLACKBIRD
I thought it was going off as it seemed dryer, so tried to sand it, no go just the same, dont know what to do now
Apart from takeing up another hobby :S :S
12 Jul 2014 11:59 #98 by old fart
Replied by old fart on topic THE CYPRUS OWN DESIGN 2m x 2m F3A
Try using acetone to remove it, acetone won't harm the resin that has cured. :)
Thanks: Eric, THE BLACKBIRD
16 Jul 2014 12:06 #99 by THE BLACKBIRD
Looks like im going to have to try the acetone Owen as it still will not sand
16 Jul 2014 21:48 #100 by old fart
Use it with a scotch-brite scouring pad and do small areas at a time. :)
04 Sep 2014 19:27 #101 by THE BLACKBIRD
After a couple of months stood in the corner the bloody thing is still tacky to touch, so i went and got a bottle of acetone and started to have a go
What a sodding job this is going to be, the scotch brite bunged up straight away so iv been all afternoon and tonight with a razor scrapeing , acetate, scrapeing and getting in a bloody mess with the gunk thats coming off, it sticks like kaka to a blanket
The outcome is that i have done ONE WING :sick: :sick: and it is still a bit tacky but i cannot get any more off, so tomorrow ill either put another coat of resin on the wing or a coat of primer filler and see how it comes out
Thanks: Eric, Klipkopwildlife, Quorneng, blue123, old fart
05 Sep 2014 07:21 #102 by Ex-Member
Replied by Ex-Member on topic THE CYPRUS OWN DESIGN 2m x 2m F3A
I really do admire your stoicism on this one BB.......I hope the work will be worth the effort in the end. :)
05 Sep 2014 08:25 #103 by Si_B
Replied by Si_B on topic THE CYPRUS OWN DESIGN 2m x 2m F3A
If you are going to spray something onto it, could I suggest doing a patch on the underside just to check. If it reacts or does not dry properly, you may end up with more of a mess and scrapping the wing. I wonder if you could try a test piece of cloth on the underside as well or somewhere out of site to see if will cure properly on the surface you currently have?
Simon
05 Sep 2014 12:42 #104 by THE BLACKBIRD
Ha, Hi Simon already sprayed the wing BOTH sides with primer filler so we will see :whistle: :whistle:
05 Sep 2014 21:20 #105 by Si_B
In for a penny.....hope it dries off.
Time to create page: 2.023 seconds
