Tiger Moth
12 Feb 2021 08:02 #106
Replied by Klipkopwildlife on topic Tiger Moth
Just been to that site Simon, it's hard to tell whether you're looking at a full size or the most amazing model I've ever seen! It is scale, the only shot of the front cowl gives it away. Definitely shows a longeron running down both sides, I'm tempted to use 6 x 3 or 1/4" x 1/8" which would give 40mm x 20mm on the full size.
12 Feb 2021 08:14 #107
by paul d
Replied by paul d on topic Tiger Moth
Just flicked through the book..the fuselage is made up of 7/8ths round and square tubes, the bulge behind the cowl is a step to allow access to the fuel tank..pictures to follow.
12 Feb 2021 09:59 #108
I would guess the longeron would be to stop the canvas flapping against the steel tubing which would be bad news for longevity of the canvas.
That's great Paul, what book is that?
12 Feb 2021 11:02 #109
by paul d
12 Feb 2021 17:08 #110
Found a second hand one locally Paul for 40quid, I should have it next week if our road is open. The short way to Town is 61km, it's the long way that's going to be opened, 160km!
12 Feb 2021 18:48 #111
by paul d
You won't regret it..it's a brilliant book, you could overhaul.a real one using it..Don't want to piss you off but it's around £13. here....sorry mate
13 Feb 2021 07:12 #112
I know this Paul, but by the time they send it to Forward2me and they courier it on it's cheaper in the end to buy the second hand one locally.
Thanks: Eric, paul d
- Thank you received: 14470
13 Feb 2021 08:24 #113
Replied by Eric on topic Tiger Moth
Plus there's less chance of it getting 'mislaid' en-route!
- Flytilbroke
- Thank you received: 1987
13 Feb 2021 10:15 #114
by Flytilbroke
Replied by Flytilbroke on topic Tiger Moth
That sounds like the West and North West of Scotland with what happens on the A85 and the A82. Multiple times a year. Hope it works for you and you get moving again.
26 Aug 2021 12:05 #115
Finally getting back to this, I'm going to use 6mm x 3mm balsa as the rubbing strakes, they extended either side of the fuselage from the leading edge of the tailplane to the rear of the cowl. There's another one that extends along the centre line of the fuselage floor, also from the leading edge of the tailplane to the rear of the cockpit floor. Everywhere in fact, where there was diagonal steel bracing, I'm sure it would have been to stop the doped fabric flapping against the tubing at higher airspeeds.
26 Aug 2021 12:11 #116
by paul d
Nice one Klippy, one day I'm going to build a tiger
26 Aug 2021 16:33 #117
Replied by Quorneng on topic Tiger Moth
Indeed if you look at any open frame fuselage the fabric covering was kept clear of the frame by added pieces of wood.
The ridge down the side of the fuselage is clarly visible in some of these pictures .
It was not unknown for areas of the fabic to be 'laced up' as well so you could get access inside.
Time to create page: 0.805 seconds
