Precedent T180 Restoration
- squareflux
- Thank you received: 328
Time to start the wing rebuild.
- squareflux
- squareflux
I watched a video of someone using this same resin, on a wing joint, and it looked quite thick to apply, and needed a lot of work.
But I've also watched some glassing guides where it's thinned with rubbing alcohol, and goes on easily with a brush.
I've used fibre glass quite a while ago, on a large mould, and the resin wasn't thinned then. But I don't want to mess this job up.
- Flytilbroke
- Thank you received: 1987
If you paint some resin onto the bare wing first, in the area you are going to glass, then put the glassfibre on, and stipple it in well, adding a bit more resin on if needed, you get a better 'wetting'.
Any white patches you see are air bubbles, and need eradicating!
- squareflux
The plate is 3mm ply. The supports that the servo would be screwed to are thick balsa.
I'm also going to add a couple of spars in the wing that the plate would screw into, these are also balsa.
So my questions, is balsa strong enough to screw the servo and plate to, or should I use ply?
Is this mock up good in terms of the layout of the supports?
- squareflux
Is CA ok for holding this all together, or is 5 minute epoxy the one to use?
I'm sure I could find some guides on youtube, but it's also a minefield.
- squareflux
I've got some Gorilla Wood Glue, the white stuff, so I'll use that.
