- Thank you received: 328
Precedent T180 Restoration
- squareflux
Anyway... I started tidying up the fuselage. The window plastic had been epoxied on, so was a royal pain in the a*** to get off. I had to skim over with light filler and sand it.
I also planed off the epoxy from the tail. I think I'll probably replace the wedge of Ply when I rebuild the tail, as I want to create a slot for the tail, down into the fuselage for more support.
I also think I'll either build up, or build a new servo tray. There's not currently a place to fix the receiver to.
(before and after)
- Thank you received: 14471
- squareflux
The Eneloop chemistry is 1.2V but 6.1 v would not be a surprise when under charge.
- squareflux
It was like this...
- squareflux
The plane came with the mount at 45 degrees.
So I was wanting to mount my engine either at the same angle, or 90, so the exhaust goes underneath. There's a channel that seems to be for it.
But that would make it tricky to get the throttle cable to the carb.
It's not a great photo, but you can see it's quite low down. So I'll need to work out what to do. I'm hoping to not have to redo the firewall, as that'll be a lot of work.
- squareflux
I'm still in 2 minds whether to try and rebuild the tail from scratch, or just repair the existing one. All that needs replaced is 2 ribs, and the sheeting on the underside where it joins the fuselage. I could just beef up the area to strengthen it.
Almost any repair tend to add weight to achieve the same strength as the original. Even a few grams at the tail needs several times that in the nose to compensate. If your motor is lighter than used in the original extra tail weight will only add to any ballast required.
A new build tail plane should match the original's strength and weight.
It all comes down to a judgement decision.
- squareflux
It would be a satisfying achievement if I managed it, but feels like a long shot at the moment.
And the other end is ready threaded just right for a clevis!
- squareflux
I picked up a new, but second hand scroll saw for £40. It's never been use so seemed a bargain.
I'm now thinking about how to cut out the ribs for the tailplane.
My plan is to trace the outline of the rib from the plan, then make a template of it from poster card. Then use that to mark out the ribs on balsa and cut them out.
Anything wrong with that plan? I've never scratch built from balsa before.
If I were doing it I would actually use the scroll saw to cut a ply template. When you are happy with the profile, for a power plane tail a constant smooth shape is more important that the exact profile, I would then use that as the master and actually cut round it over the balsa with a suitable scalpel blade.
With a bit of practise you should find the ribs end up almost exactly identical and need only the lightest of sanding.
If the ribs have spar 'notches' in them cut them out, or wood file them out, after the rib has been cut out.
- squareflux
Quorneng wrote: I am not sure you need a scroll saw to cut out balsa whereas for plywood yes.
Well maybe I didn't "need" one, but I fancied getting one for a while, and I'm sure it'll be useful for future builds.
Quorneng wrote: If I were doing it I would actually use the scroll saw to cut a ply template. When you are happy with the profile, for a power plane tail a constant smooth shape is more important that the exact profile, I would then use that as the master and actually cut round it over the balsa with a suitable scalpel blade.
Thanks for the tips. I thought about just using a scalpal, but thought it would be more consistent with the saw. But I can see how the Ply template would work with the scalpal.
As you've now got a saw you could make 2 templates and use the sandwich method to produce your ribs, clamp strips of balsa between the templates and cut and file to shape...one set of identical ribs!!
