Precedent T180 Restoration
18 Aug 2021 07:52 #136 by Klipkopwildlife
Replied by Klipkopwildlife on topic Precedent T180 Restoration
That looks very substantial, no need to add any extra weight there.
  • squareflux
20 Aug 2021 07:38 #137 by squareflux
Replied by squareflux on topic Precedent T180 Restoration
Almost done with the tailplane. Just the ends and sheeting to do. I'll post a photo when I've done it.
One thing I'm finding difficult, but enjoyable, is working out the order to build in. I suppose with a kit, there'd be a list of instructions on the order to follow. I find myself stopping to go off and think about it, before doing the next step.
Just now I'm thinking about whether to do the top sheeting or the ends first.
I've got the bug for scratch building though :lol:
20 Aug 2021 08:13 #138 by Klipkopwildlife
Interestingly most kits leave you to think it out for yourself, unless it's crucial.
  • squareflux
23 Aug 2021 19:21 #139 by squareflux
Done the tail, apart from profiling and the tailfin fitment.
23 Aug 2021 19:49 #140 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Precedent T180 Restoration
Looking good Sir
Thanks: Eric, Klipkopwildlife, squareflux
23 Aug 2021 21:58 - 23 Aug 2021 22:01 #141 by Eric
Replied by Eric on topic Precedent T180 Restoration
You might like to insert a small spreader-plate in the rudder for the control horn to work on.
Last edit: 23 Aug 2021 22:01 by Eric.
  • squareflux
23 Aug 2021 22:36 #142 by squareflux
Yeah, I've still got this to do. I need to clean up the elevator, and I still need to check if the old rudder can be used. It was a bit short against the plan, so I might need to remake it as well.
24 Aug 2021 07:51 #143 by paul d
Replied by paul d on topic Precedent T180 Restoration
looks good to me, nice work.
  • squareflux
25 Aug 2021 10:55 #144 by squareflux
I started work on the end of the fuselage. The plate where the tail was attached was too covered in old epoxy to use, so I removed it and made a new one from light ply. I also removed the end balsa block where the rudder was attached, as it was in a mess as well, so need to make a new one of those. I'm going to put a couple of support strips under the plate to give it more to attach to.
I have some snake exits to use, but there was no guide on how to attach them. Has anyone used these? I take it they go on the outside surface, but what's the best way to attach them?
25 Aug 2021 11:18 #145 by Eric
Snake exits - drill/poke a hole in the blunt end, then epoxy it to the sheet where the snake protrudes.
They are supposed to reduce drag, but in reality they just make a ragged hole look tidy! You still have to secure the snake outers so it can't slide about.
Thanks: squareflux
25 Aug 2021 14:18 #146 by Klipkopwildlife
As a reference, here's what I did on my Tiger Moth (still unfinished)
Epoxied into the deck
Sanding still to be completed, just to show the general idea, the snake is glued to the formers on the inside.
Thanks: squareflux
  • squareflux
25 Aug 2021 14:48 - 25 Aug 2021 14:49 #147 by squareflux
That's actually what the ones I took off were like. I just thought these exits might have been cleaner. They ran through holes in one former then were glued to one closer to the exit.
It seems easier to do it the way you have rather than try and attach the exits I bought.
Last edit: 25 Aug 2021 14:49 by squareflux.
  • squareflux
25 Aug 2021 16:47 #148 by squareflux
I'm going to do them like this.
They're going through a former halfway along the fuselage. Then I'll glue the snake outer inside the exit cover, and glue the exit onto the skin.
There's a bit of a gap to the furthest rear former to glue them to, and don't want to bend them to reach it.
Thanks: Flytilbroke
25 Aug 2021 17:24 #149 by Klipkopwildlife
Doesn't get any better than that, your enemy is excess outer slopping around inside the fuselage. If you do have any excess it must be properly secured.
Thanks: Flytilbroke, squareflux
25 Aug 2021 21:01 #150 by Quorneng
Replied by Quorneng on topic Precedent T180 Restoration
I am not quite sure I agree with the need to secure the snake outer other than at each end.
Geometry suggests it does not matter what the snake does between its fixed end points as the inner has to do exactly the same so there is no differential movement between them.
The biggest issue is the length of the inner free ends. No problem when pulling but when pushing the inner (it is quite flexible by design) can bow so limiting the force generated at the control horn.
A test. If you hold the control surface rigid can the snake withstand the servo stall torque. I bet it can when pulling but less likely when the servo is pushing.
Like Indiana Jones I am not keen on snakes.:P :P
Time to create page: 0.585 seconds
