Surrey flying services AL 1
02 May 2017 14:57 #106 by one tenor
Replied by one tenor on topic Surrey flying services AL 1
love the wheels how did you do you do the lacing.
03 May 2017 18:01 #107 by Ex-Member
Replied by Ex-Member on topic Surrey flying services AL 1
if you read back you will see that i used 1mm thong for the spokes.
each side is laced with one bit of thong fed through each hole as needed.
fitted the suspension cross wires today.
then i clad the rear legs.
and now i am gluing the dummy engine in place.
i made up a spacer so i could use the prop nut to hold the engine in place while the glue sets.
we plod on slowly.
05 May 2017 20:31 #108 by Ex-Member
Not done much just lately, not been in the mood.
plug wires fitted, engine faired in.
that is all.
06 May 2017 15:45 #109 by one tenor
Lovely job. Could almost believe it was full size
08 May 2017 20:10 #110 by Ex-Member
wing centre section glued in place now.
3D printed rigging mounts have also now been fitted.
I can start to think about making up the rigging next.
not a job i am looking forward too i must admit.
08 May 2017 20:24 #111 by Squirrelnet
Replied by Squirrelnet on topic Surrey flying services AL 1
I'm assuming thats the the underside of the centre section the photo, nice little brackets.
Its tricky rigging but it's going to look great when you've done it
10 May 2017 18:27 #112 by Ex-Member
well today has been a camper day, with a small bit of model work late afternoon.
covered the nose section with tissue and three coat of sealer, being hot the sealer dried very quickly.
then i sat down and started adding some chrome builders tape to the nose section to try and simulate the alloy hood.
not great, but it will do me.
might look better once i have added the hinges and catches.
we live and learn something new every day.
10 May 2017 18:50 #113 by Firewood
Replied by Firewood on topic Surrey flying services AL 1
Not easy stuff to work with Mr B I fined a soft cloth helps to smooth it down.Had wondered if wetting the surface with water and a spot of a well known washing up liquid might work,one thing once it's on it ain't going to come off :)
Thanks: Ex-Member, boz, Squirrelnet
11 May 2017 18:26 #114 by Ex-Member
Been doing little bits today, not been in a building mood.
still each little bit done is a bit less to do in the future.
12 May 2017 17:45 #115 by Ex-Member
Been a long day of getting nowhere :(
printed out and fitted the lower fuselage rigging points.
from what i can see on the pictures the two upper wires run to one fitting at the main spar point in the fuselage.
need to repair the fuselage where i had to open it up to gain access.
now i can start looking at the wing struts.
all the fittings for the rigging have been ordered now, so very soon i will have a fully rigged airframe.
Thank you for watching
Tony B :)
13 May 2017 17:51 #116 by Ex-Member
well after the camper painting got washed out, bloody weather.
I have made up the wing strut cores.
metal posts glued into balsa cores, when all set i can then sheet them in Depron and sand to shape.
dihedral is within 2mm difference each side, mind you once i get the rigging made up i will be able to tweek it every time i assemble the model at the flying field.
So, i am waiting for all the rigging parts to turn up now.
13 May 2017 18:19 #117 by Firewood
That is looking superb :woohoo: difficult to appreciate just how large it is. :)
13 May 2017 18:38 #118 by boz
Replied by boz on topic Surrey flying services AL 1
Looking great tony, it's coming together now great thread, keep plodding, boz. :) :)
18 May 2017 18:58 #119 by Ex-Member
Printing the screen frame this evening.
Cabane struts made, centre section covered.
we plod on.
18 May 2017 19:10 #120 by Squirrelnet
It's building into a very attractive model Tony
Time to create page: 0.714 seconds
