Piper Tripacer to Pacer refurb
- Inactivated User
be an interesting thread to follow.
i should be able to pick up some good tips then.
- CeeJayP
- Hi Peeps
- Thank you received: 833
any way heres a couple of pics purely for interest
i have picked the full size aircraft i am doing the scheme of
here,s a picture of it in its 1980,s guise
and here is one of it now
how neat is that
i also have a load of detail photo,s i took at Stow Maries last year when it flew in for the vintage aircraft weekend i spoke to owner to will be neat to get the two together
chris
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
So as Blue Peter says, here,s on i did earlier
hmmm dont see any sticky back tape and plastic washing up bottles so you dont get the blue peter badge Mr P!
Must admit prefer as a taildragger. Seen a nice colour scheme on a tripacer on google- cream with a burgundy trim
- CeeJayP
- Hi Peeps
the reason for the colour picked is its history, it was a tripacer, and i know the owner slightly and it fliy,s into Stow Maries where i spend a lot of time over the year
chris
- Inactivated User
alan cantwell wrote: .....carry on losing weight, then start on the model
- CeeJayP
- Hi Peeps
chris
- CeeJayP
- Hi Peeps
been and had a play with camera and will try to show the major components in its change of identity fro Tri to Pacer
first of all what has been removed.
this shows the main and nose wheel assy,s the main is made from 1/4 inch thick alluminium plate!!!! and is very heavy and has no springing other than flex in the material. obviously would have been two main wheels but binned em and can only locate one for pics.
this one is all the accompanying fittings for the nose leg to this add a servo and plywood mounts and all the box for the nose to mount on that was made from 1/4 ply.
this last shot shows where all this ply mount and nose leg used to be, now all open, fresh air is much lighter
chris
- CeeJayP
- Hi Peeps
- CeeJayP
- Hi Peeps
- CeeJayP
- Hi Peeps
its made from medium carbon 6mm steel bar,
axle joint
here is the suspension assy inside fus
the suspension is made from two short lengths of springs for each leg one soft one hard to allow for some progressive springing. the terrible finish is cheap paint blasted on to stop it rusting!!
chris
- CeeJayP
- Hi Peeps
first the mounting points on fus bottom, the exterior brackets bolt through the fus to a strap that goes accross fus to take the landing loads.
Attachment DSC_0015.JPG not found
fus attachment/pivot point
Attachment DSC_0014.JPG not found
and one of the tail wheel, cheated here its a commercial one
chris
- CeeJayP
- Hi Peeps
this one shows the fus underside just to illustrate whats changed, all the underside was previously sheeted in 1/2 inch balsa
this one is a view of the underside of motor with standard exhaust boxes, these are fine noise wise but do not let the motor produce its best, so these will be changed for the can in the next picture, hence the large space still where the noseleg mounts were
chris
