- Thank you received: 10722
A control line stunter
- Flytilbroke
- Thank you received: 1978
Did not Tony say it was nose heavy?
So i have just been in the shed and partly glassed the c/line models fuselage as im going to paint it, cannot seem to get on to well with the film
If i do another it will be old style nylon dope and paint
No pics im afaid cannot get them to load
Then applied epoxy resin with a brush then laid the cloth onto the fuselage then worked the cloth into the resin with my credit card
and at the same time scraped all excess resin off
Left it to go off and harden for a couple of days the sanded it back as close the the cloth as i dare, then gave it a light spray of paint and sanded it down, this will form the warning to stop sanding after iv given it a coat of primer filler and sanded that off
Talking of weight i weighed the model before i glassed it and was pleasantly surprised that it came out at 43oz and that was with the engine and silencer fitted and 2 chunks of lead in the rear from when i balanced it, the lead is loose so i will re balance it when finished, weight is king in a stunt model
