- Thank you received: 10572
ASW 17 Sailplane
- Thank you received: 19042
There was also a BGA approved modification to create more conventional top and bottom airbrakes that increased the available approach angle.
Not like the good old days where the T49 trainer glider's big air brakes kept it below its never exceed speed even in a vertical dive!
- jon.in.swansea
- Thank you received: 1147
And yes it will but only just, it will not fit in the wooden box so it will not be coming back
Fuse and one wing in here
And the other sections in here
So i can just squeeze my stuff in as well, the rudder tailfeathers and elevator are inside the Bucker
Ill star to glass the fuse tomorrow then get a second coat of resin on over the weekend
So that its gone off by Tuesday and can go in the box
- Thank you received: 14141
AND NOW a disastrous day in the shed i started the glassing of the fuselage
Laid the cloth on mixed up enough resin to do the job and more using her indoors scales as mine would not work, gave it a really good mixing and started spreading it on with an old credit after a while i felt the paper cup with the resin in getting hot in my hand, it had started to go off, and quickly and melt my credit card
Not to amused as its expensive stuff the Wests resin, i thought i must have mixed it wrong, so mixed some more and carried on
Only to find the new cup getting hot in my hand again so rushed to got as much done as possible as i do not have any other
By this time it was foaming it the cup ( the first mix just went hard ) and choking me
Iv had it a while but not to long i got it to do the control line model
Then i had to sneak her scales back inside as she had come home
Im sitting here doing this post and my face is stinging from the fumes
Afraid it will have to go to S.A. like it is as i dont have time to get more resin sand it all back and do the top half
