ASW 17 Sailplane
14 Mar 2026 08:59 #196
Replied by Klipkopwildlife on topic ASW 17 Sailplane
Cloudy, overcast and spotting with rain today but I'm going to put the Bucker batteries on charge, maybe we'll get a gap in the weather.
18 Mar 2026 13:53 #197
Today was also the ASW 17's turn,another disaster!
- Thank you received: 19042
18 Mar 2026 13:57 #198
Replied by Quorneng on topic ASW 17 Sailplane
I fear it has to be launched a good bit faster than that!
Try setting the flaps for a hand launch.
- Thank you received: 14141
18 Mar 2026 15:13 #199
Replied by Eric on topic ASW 17 Sailplane
Launched too slowly and pointing down! And the wings were rather droopy!
18 Mar 2026 17:02 #200
At 81 I couldn't do any better! Yes, a terrible launch.
Thanks: Eric, Flytilbroke
- jon.in.swansea
- Thank you received: 1147
18 Mar 2026 17:15 #201
by jon.in.swansea
Replied by jon.in.swansea on topic ASW 17 Sailplane
An absolutely beautiful model to look at. And what a wing span!
And the model was out-of-camera after its connection with the ground but Mary's exclamation is I hope not indicative of the number of separate bits. After a few cups of tea or something stronger perhaps a debrief?
18 Mar 2026 19:18 #202
Unless a plane has a better than 1:1 thrust to weight there is nothing wrong with a slight nose down slow launch at least what thrust it has will go towards making it go faster. Nose up it will struggle to even maintain the slow launch speed.
Got any suitable mound/hill?. At least then the ground falls away as you launch giving it more time to speed up.
- Flytilbroke
- Thank you received: 1969
19 Mar 2026 09:05 #203
by Flytilbroke
Replied by Flytilbroke on topic ASW 17 Sailplane
Sadly, it was pointing Down when launched, as has been mentioned. Flat or slightly nose up would have made a difference. The "run" part actually made it worse as is often the case, as it reduced the ability to push it at the correct angle.
19 Mar 2026 12:10 #204
Us old folk cant run worth a damn anyway, we're more likely to trip over our own feet.
My chosen method is - assuming a left-hand chuck - get balanced up (self and model) with the left foot slightly behind, step forward with the right, push off and step forward with the left, and put the body weight and momentum into the left-hand launch.
The twist from the waist/hip, and the left foot forward, avoids a face-plant - while the power comes from the right leg.
Time to create page: 0.178 seconds
