Anet A6 3D printer
Banggood as usual, the box weighed in at just less than 10Kg or 22lbs.
First view of the inside.
Do not dig too far, you'll get into trouble! Provided you open from the correct side almost all of the bits are in the correct order.
Well packaged there was no damage to any of the component parts.
There are no printed instructions so I spent about a day cruising t'internet but could only find U tube instructions. Didn't use em, can't work with em! Frustrated I returned to the box and discovered a plastic packet with a memory stick in it. It's hidden under the blue 'H' (Hot bed support) underneath the bubble wrapped plate which is the Hot bed itself.
This kit is designed to arrive in a place where there are no tools, these are the tools you get. The USB stick has a slot in the back to take the micro SD card. 16Gb is supplied, more than you'll ever need but buy a spare, you're going to use it a lot.
The white spots you see all over the place is Polystyrene balls from the packaging, by the time you've pulled the protective paper off the parts the static grabs everything! Pulling the protective paper off takes longer than the actual assembly!
My first concern, not a washer in sight! Nasty.
Adding the 'Y' motor and limit switch, note the way every wire is properly terminated with a plug.
The sharp eyed will notice I traced every single part, this is because I have visions of having some of the strength parts laser or water cut in 6mm Duralumin at a later stage.
This has a bearing to carry the toothed drive belt, I see there is a modification to make it stronger and have an arrangement to tension the belt.
And mounted on the gantry, you have to be careful where you put the washers and nuts!
They're held in with simple end covers.
In and ready to receive the Hot plate.
Slots are use to receive the 3mm plated screws with cut outs just large enough to hold the 3mm plated nuts, no washers are supplied.
Location is by tab and slot, tolerances are good +-.25mm but there is always a small amount of slop. Best not to tighten everything down (just a little nip) until the whole thing is together.
The black bits there are to clamp the toothed drive belt, to my mind they're the wrong size, so will be among the first modifications once we're up and running.
Although 'as per instructions' I later changed the location of the cross bar to underneath the main bearers, this gave a better (but still not perfect) location for the drive belt clamps.
It's mounted to the 'Y' axis with long screws, springs and wing nuts.
Note how every bag is properly marked.
Now in position, you're not told where to site the connector socket, at the back is best, out of harms way.
Now we start to assemble the 'Z' assemblies, in machines the 'Z' axis is always the one that plunges into the component.
There are 2 'Z' drives so you drive the bridge squarely up and down.
The Extruder head is also pre built
Acme screws in, guide rails in, ready to push the guide rails across to engage in the Extruder head.
And done.
And blower
The screws supplied for this were countersink! Unforgivable!
Then the limit switch, you can see I've countersunk the holes in the support plate.
Only countersink screws supplied, again!
Where countersink screws were supplied I've countersunk where ever necessary, please excuse my OCD
Don't forget the stand offs, I managed to lose one!
Note all the wiring coming through the back, I decided to leave them until after proving trials
