Anet A6 3D printer
As for removing and replacing the micro plugs, I ground an old pair of pliers to firmly grip the body of the mostly JST types. I use them any time I want to fiddle with anything. One of my earliest problems was the fan plug for the Extruder wasn't making reliable contact, due to (I think) using the wires to remove it.
The thought of some sort of failure at 16.5 doesn't bear thinking about.
I must say I get nervous at over 3 and favour making it in parts even if it ends up being 'screwed and glued' together.
I now have Glass fibre drive belts.
A PEI build plate (It's magnetic and can be removed and bent to release the print)
A Titan extruder that can go to 285oC
A Bowden cable feed for the Filament to get the Extruder stepper motor off the X axis.
An Auto home Inductive sensor
A new main board with replaceable plug in stepper drivers and 512k of memory.
A new screen with 2 modes, one old style and a new style touch screen. (waste of money, I leave it on the old style)
A firmware upgrade to Marlin 2.0.9.1 which gives me all kinds of fun extras like backlash compensation, mesh bed leveling and a lot more.
It's taken me around 5 weeks! I've learned a lot, would I do it again, probably not.
Now all I have to do is learn how to use or draw in 3D cad!
I do wonder if a remote extruder drive will encourage stringing as I would expect the filament 'retraction' operation to be a bit less precise when compared to having the drive just an inch or so above the nozzle.
I do agree it should make changing the filament much easier as some filament stays in the nozzle all the time.
Getting a new filament through a local drive can be a pain particularly when it breaks by itself just inside the drive when the machine is cold!
The brim still has to be broken off and fettled.
As part of my Bowden cable modification the original was printed in PLA which tended to deform on very long prints (>10hours) because the Extruder stepper gets very hot.
The secret with ABS is, for me, Heat, the bed is 100oC and the extruder at 235oC. NO fan cooling of the work piece. Any fan cooling causes warping and the base of the object must be roughly square, 70/30 is about the limit otherwise it warps and pulls off the build plate anyway!
Today my Anet A8 decided to pay up again.
The bed thermocouple works fine and the desired bed temperature is correctly displayed but when the bed reaches that temperature it does not switch off. I only realised what was happening when the PLA print started to descend into a molten mass. I suspect the bed got to your sort of temperatures!
Even with the bed temperature set to zero it starts to heat up as soon as the printer is switched on.
Unfortunately I think it is a control board problem (again) rather than anything to do with the bed itself. Sods law as I do have a spare heated bed!
For the time being I have disconnected the bed heater and are printing cold!
I had to scale slightly which is why the second try.
I do like Cura, it's so powerful!
I am sure your A6 board would be most helpful but only if the postage is reasonable after all a new A8 board is not that expensive.
The annoying bit is by the time I have finished I could have bought a new printer which in my heart of hearts I new I should have done.
