- Thank you received: 1164
freeCAD and fuselage creation
- jon.in.swansea
I decided to redesign the spar to match the rib spacing. I toyed with adapting the rib to take a small compression spar but then opted for extending the spar and use 0.8mm plates each side to glue-join the spar (we shall see).
The trailing edge of the wing-at-aileron is a curved to match the pivot curve of the aileron. Once it sets I will remove the section of skewer at the aileron.
Last night I did the initial gluing around the aileron so that it would be stable while I adjusted the other ribs/spars/skewers. Below are the bits clamped in place.
Observation
a) The rear skewers are great for holding the ribs stable. The front skewers helped a bit but it turned out extending the spar made them a bit redundant.
b) An all-foam ARMIN is a 40 minute job from layout to attachment so it is an eye-opener for me the change in time building via ribs. Granted, I have probably made it more complex than necessary. I tend to invent wheels. I suspect there is a further hybrid design point that remove a bit of the complexity.
c) For ease of repair I might re-design the aileron for a tape hinge rather than use a pivot.
As Tony put - too much dihedral for ailerons! One will fight the other at every turn command.
That all looks very impressive.
I presume the spar joiners go either side of the spar. It should be adequately strong but it does rely heavily on the glue strength at the top and bottom edges of the plate where the stress will be the greatest.
If it were me I would actually test a joint to see how it broke. Ideally it should not break at the joint at all but somewhere else along the spar.
- jon.in.swansea
Please shout at me to make the change now if continuing is going to lead to a lot of pain.
Testing the joint - good idea. The central dihedral brace is quite strong. I could print another section glue it and see how it fails.
There is space before I cover to create additional 'U' shaped pieces to glue to the top and bottom of the join to give some extra resistance. -Jon
- jon.in.swansea
- jon.in.swansea
I cleaned up the spars, and plates and added a "U" piece for the top and bottom as seen below...
This time I used epoxy and gave it about 18 hours and I really had to work to break it.
That is what I have used for the main wing. Below all of the bits are in. I added some trays for the servos.
I notice looking at the centre section that the first ribs that I wanted to be ~25mm away from the centre are not quite the same - so much to review in the moments before the epoxy sets! This is outside my comfort zone and I know that subsequent prints and builds will lead to a new normal.
As seen it is 142g. If the foam is another 20-30g and 15-20g for servos and wiring that is ~190g for 165x960 and my ARMIN wing 900x180 is 177g (with wiring and servos). I would probably loose the leading edge skewers if I did it again but that is only ~5g.
The printed ailerons are 8g each but I think they are lovely beasties as well as having a centre pivot which is different from a taped upper hinge point.
Are all the spar sections printed with the same structure?
If they are and the spar is strong enough at the root it will be many times too strong and thus heavier than necessary towards the tip. This is particularly so with a constant section 'plank' wing.
A simple test is to lift the complete with battery by just its wing tips. If it can you it will be adequately strong to fly and indeed it would be safe for moderate aerobatics like a gentle loop.
My printed spar wing had 5 "I" beam sections. The middle one had thick top and bottom flanges.
The tip section although of the same physical size had thin top and bottom flanges.
The spar sections were super glued together with a thin plate super glued over the top and bottom of the spar.
It did survive a rather alarming load test.
A centre load nearly twice the weight of the complete fuselage including battery is equivalent to pulling nearly 6g.
Even so I am pretty sure it will still eventually fail at the root!
As you have found out POR is not a particularly good 'high stress' glue. I have just pulled apart a large area POR glued printed joint that had been untouched for 5 years. The separation did not damage the printed surfaces in any way!
- jon.in.swansea
Essentially I had a rectangular shape that I subtracted ellipse shapes from. I printed them flat with 2 perimeters, 10% triangular file and 2 layers top and bottom. I wanted to be able to glue the side plates on to something substantial and had not though about only a top and bottom flange glue plate.
Your images are interesting with the varying depth of the flange. The rib printing with zero top layer I understand. I am puzzled how to get specific flange thickness as well as the exposed triangular infil. Ah! Unless you specified say 4 perimeters and that got you the additional flange thickness? -Jon
In my case it is all done in CURA. The FreeCAD file for the spar is just a solid rectangle.
CURA was set to 1 bottom layer & zero top to give the single side. The wall count was set at 4 to give the thick flanges.
The structure between the walls is a 'grid' pattern infill with a density set to give the required pattern size. The infill Y axis was also adjusted so the pattern is in the desired position between the flanges.
The wall count is progressively reduced on each of the outer spar sections. The outer most section had a single wall.
The root spar section with thick flanges weighed 5g whereas the outer most with the same overall dimensions only weighed 2g.
- jon.in.swansea
I see in the image a figure of 40% for the spar location - it is actually at 30%....
With a sheet foam covered wing is the lateral strength of the spar an issue?
It should be glued along its entire top and bottom length to the foam skin. All the foam has to do is to keep the spar straight and it will achieve its full vertical bending strength.
It all comes down to the glue strength.
- jon.in.swansea
The hybrid foam and rib is a bit heavier than the all foam wing. For a first try it was a great learning experience. And the heat forming and slipping on the whole skin does seem to have worked - after the skin set I have started cutting away the excess around the ailerons and tidying up the ends and sanding the trailing edge.
There is a few mm gap at the front centre join of the skins and I haven't figured out how best to fill gaps in foam other than to cut some slivers and glue them in. With other scratch builds I might have used hot glue to fill.
