Prusa Mk 4
26 Jan 2024 16:50 #1 by Klipkopwildlife
Prusa Mk 4 was created by Klipkopwildlife
I've finally chucked in the towel with my Anet A6, I can't get constant sticktion across the build platform. It's done me well, I think the problem is the heated bed. I tried to buy a new bed in Oz without success. Mostly because nobody opens until the 24th or so. Knowing that Jon is mega pleased with his Prusa mini I've just ordered a Prusa Mk 4. Blame it on the need for some retail therapy while suffering from Covid!
Thanks: Eric, Flytilbroke, Quorneng, THE BLACKBIRD, Janine
03 Feb 2024 13:09 #2 by Quorneng
Replied by Quorneng on topic Prusa Mk 4
Klippy
I appreciate your Anet A6 has a glass(?) bed whereas my A8 is aluminium but despite several print issues with its now rather worn out mechanicals the one problem I have not had, particularly with LW-PLA , is bed adhesion with its masking tape covered bed. The tape does have to be replaced quite often which is a bit of a chore.
As a recent example this significantly offset single wall duct was perfectly secure with just a 3 line count brim. It was prised off with a sharp blade without damage to the part or the brim..
Just an observation.
04 Feb 2024 08:14 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic Prusa Mk 4
Hi Simon, the A6 bed is also aluminium but is now slightly dished, my own fault, by about .2mm. At the moment I can't find another anywhere except the Anet site but they won't send to South Africa.
I ordered a Hotbed XY-3 Pro from a local site (www.botshop.co.za) on the grounds that its Specifications said it was 220 x 220mm.
What arrived was 315 x 315mm, Despite a number of emails they haven't deigned to reply.
04 Feb 2024 11:58 #4 by Quorneng
However useful a bigger bed might be I presume 373x375 will simply not fit.
II could physically get a 300x300 on my A8 although of course it would not print on the bigger area.
05 Feb 2024 14:06 #5 by Klipkopwildlife
You can see from this shot the maximum between the vertical sides is 235mm
The new bed is just ridiculous!
05 Feb 2024 15:06 #6 by Quorneng
Interesting that my A8 is actually a bit bigger.
he bed is not actually limited by the verticals which is 300 but by the motor motor mount plates which limit the maximum possible width to 275mm. This ignores the fact the bed heating plug that needs a 20mm clearance on the bed left side..
I hope you get a refund  or batter still a replacement bed of the right size.
05 Feb 2024 15:49 #7 by Klipkopwildlife
The local unwritten rule is "never give the money back"
10 Feb 2024 07:38 #8 by Klipkopwildlife
I must say I'm mega impressed with Prusa, my kit arrived on Thursday, we were in town, Mary is not well, the severe anaemia is fixed but now her Sciatica giving her gip!
I was able to get he box home and in the den without her being any the wiser!
The Prusa is any colour you like as long as it's black and orange.
The black parts are powder coated aluminium, the fit and finish is nothing short of amazing
The main frame is a casting, the 'feet' are 30mm extrusions. Knowing castings can 'pull' I checked the frame for flatness, perfect.
Here the end plates are on, the instructions say check the unit for 'rock' on a flat surface, up to 2mm is acceptable, there was none measurable!
10 Feb 2024 07:44 #9 by Klipkopwildlife
The next job is to mount the power pack and the 'buddy box'
Next up is the Y motor and return wheel.
There are a few cabling clips to go on the base.
The format of the printer is identical to the Anet A8
10 Feb 2024 07:50 #10 by Klipkopwildlife
The frame now gets put on one side to concentrate on the X axis.
All of the orange parts are ABS, fit and finish is so good that I didn't have to relieve or adjust anything.
You do have to lubricate the bearings using the supplied grease and 3D printed applicator.
Guide rails and bearings in. The Z rails are 10mm the X rails are 8mm
10 Feb 2024 07:53 #11 by Klipkopwildlife
X carriage is on, not fully secured, along with the motor, tensioner and toothed belt.
10 Feb 2024 07:58 #12 by Klipkopwildlife
The Z motors come with the lead screws already fastened, nothing can be seen I presume they're glued on to the motor shafts.
Finally the X carriage is lowered on to the Z rails and held temporarily with a supplied clip to stop it from dropping while you put the lead nuts on.
I'm very impressed with the level of attention to detail. Next up, the extruder.
10 Feb 2024 08:17 - 10 Feb 2024 10:27 #13 by Eric
Replied by Eric on topic Prusa Mk 4
Totally irrelevent - but I do wish there was some way - in written English - of differentiating between lead (the heavy soft metal) and lead (the cord that you tie to a dog, etc!)
Last edit: 10 Feb 2024 10:27 by Eric. Reason: typo
10 Feb 2024 10:59 #14 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Prusa Mk 4
Maybe we should call it Leeds
10 Feb 2024 22:04 - 10 Feb 2024 22:08 #15 by Quorneng
You could always call it plumbum. It s after all where oure word plumber comes from.
That Prusa looks like it will be my A8 replacement.
Last edit: 10 Feb 2024 22:08 by Quorneng.
Time to create page: 0.337 seconds
