Vickers Viscount
the cirrus moth is nearly at the covering stage.
cant be arsed with the dorinier at the mo.
so.....................................................
i got the plans for a vickers viscount in the post today.
60 inch wing span c/l model, so i will have to convert it to rc.
4 electric motors
i have to modify the plan from control line to r/c so got to add ailerons and rudder to the design.
also work out where to put everything.
- Grumpy42
they look good from a distance, but close up they are no where near perfect.
still once its all covered and sanded you wont see the formers anyway.
might try to get the vertical stab built and fitted as well, we shall see.
Not a flat surface in sight and quite a bit of compound curves as well.
Are you going to model G-AMOG?
- Grumpy42
I note that this plan is a control line model which you are modifying For RC. I wonder how scale it is and if you will have to check the moment arm to the tail and - the areas of the tailplane, elevators and fin/rudder. BTW - I've just been reading an article in RCM&E about multiple electric motors and the wiring required - you are going to have fun aren't you? Yep - it is the March 2012 issue - which we've only just got down here - penalty of living in the Colonies.
yes it is going to be fun.
i get bored with cutting ribs and formers, so i like to cut a bit and build a bit, then go back to cutting. that way you have something to show at the end of the day other than a pile of bits.
i might fit small people, then again why bother its not for comps and in the air they will not be visible.
