Vickers Viscount
13 May 2012 00:56 #31 by Ex-Member
Replied by Ex-Member on topic Re: Vickers Viscount
well today has been a slow day.
i have managed to get some more planking done round the nose and cockpit area.
i have to trim the balsa away from inside the cockpit area, then do the roof.
13 May 2012 23:11 #32 by The Beard
Replied by The Beard on topic Re: Vickers Viscount
Interesting to see how your developing the cockpit Tony.
13 May 2012 23:19 #33 by Ex-Member
its pants at the mo.
need to trim the balsa back behind the front uprights and fit it out before i can do any more to it.
decided to fit the snakes in the rear so i can get on with planking the rear end.
14 May 2012 00:41 #34 by The Beard
I see your able to support them firmly which is essential isnt it.
14 May 2012 01:16 #35 by Eric
Replied by Eric on topic Re: Vickers Viscount
The middles aren't too critical, but the ends of the outers mustn't move.
14 May 2012 01:20 #36 by Ex-Member
the ends will be built into the fuselage at the rear and i will be fixing a cross bar to take the servo ends.
need to decide where the servos are going first.:P
14 May 2012 06:47 - 14 May 2012 06:50 #37 by Grumpy42
Replied by Grumpy42 on topic Re: Vickers Viscount
Eric wrote: The middles aren't too critical, but the ends of the outers mustn't move.
Sorry but I have to disagree with you Eric - the middles still need to be positively located other wise you can get a build up of flutter. Especially if it is a highly stressed control surface. This becomes more critical the longer the unsupported length of the snake becomes. I support snakes at every bulkhead or every six inches - which ever is the shortest.
Last edit: 14 May 2012 06:50 by Grumpy42.
14 May 2012 23:01 #38 by Ex-Member
middles of the snakes have been glued in position.
and the sheeting round the rear is nearly done.
the open area along the side is where the windows have to be fitted and i have to put some seats inside still.
the open bottom will be partially planked except where the wing will be bolted in.
15 May 2012 09:00 #39 by Grumpy42
Progressing well Tony - I'm still amazed at the speed you build at. Just a thought - if you don't want to go to all the trouble of seats and windows - you could plank it all in and paint the windows on - OK - I know - I'm a philistine - or is that a pollystine? :lol: :lol: :lol: :P
15 May 2012 11:59 #40 by Ex-Member
polystine. :P
but i am thinking along those lines.;) ;)
15 May 2012 14:06 #41 by The Beard
Would not seats add a lot of weight?
15 May 2012 21:48 #42 by Ex-Member
right i have thrown it in the corner. :angry: :angry: :angry:
so i can start on the wings.:woohoo:
16 May 2012 08:45 #43 by Grumpy42
Tony B. AKA Blooper wrote: right i have thrown it in the corner. :angry: :angry: :angry:
You had me worried there for a minute Tony!!!
16 May 2012 20:30 #44 by Ex-Member
pulled the first wing half off of the board and is building the second half now.
then i need to make the dihedral braces and i can join them together.
be nacelles after that.:unsure:
16 May 2012 22:01 #45 by Ex-Member
both wing halves are off the board.
just had an offer up.
dihedral is not set yet as they need to be joined yet.
but you have to have a look see.
Time to create page: 0.578 seconds
