Vickers Viscount
23 May 2012 00:04 #46 by Ex-Member
Replied by Ex-Member on topic Re: Vickers Viscount
well today i have been mainly joining the 2 wing halves together.
each brace was made up of 3 lamination's of balsa and ply then glued in place.
then the 4 dihedral braces were cut and glued in.
after that i had to cut the bottom off of the fuselage and mount the wing in place, using the lower fuselage formers as mounts.
then you have the fun job of getting it all to line up before glue hits wood.
still we have got this far now.
wing gluing in place in the removable lower fuselage section.
the original design had the wing fixed in place, but i have had to try and work out how to make it removable.
we can plank round the wing next to lock it all together.
23 May 2012 17:18 #47 by Ex-Member
started on the planking round the wing.
this whole section comes out attached to the wing.
it will be held on with 4 wing bolts.
23 May 2012 20:39 #48 by Ex-Member
i am a right planker for building this. :P
wing in place.
but its 3 mm out grrrrrrrrrrrrrrrrrrrrrrr:angry: :angry: :angry: :angry:
23 May 2012 21:15 - 23 May 2012 21:17 #49 by Ex-Member
need to start thinking about motors.
plane weighs 2lb at the mo, so i suggest we double it and add a pound.
so a 5lb flying weight will need at 80watts a lb about 400watts of power.
so 4 100watt motors would be minimum.
4 x 150 watt should be enough.
this
something like this
might be overkill though.
Last edit: 23 May 2012 21:17 by Ex-Member.
23 May 2012 21:31 #50 by Eric
Replied by Eric on topic Re: Vickers Viscount
Too much power is always better than not enough, Tony.
You can always throttle back!
  • Seamus O Leprosy
  • Seamus O Leprosy's Avatar
  • Premium Member
  • Premium Member
24 May 2012 01:43 #51 by Seamus O Leprosy
Replied by Seamus O Leprosy on topic Re: Vickers Viscount
What size props would be scale ?
You need to get a motor a high enough Kv to spin whatever props, at the best power revs, with
the preferred lipo.
That 900kv motor is going to need a bit prop to get the watts out
You have a amp/watt meter?
I don't do smilies :-(
24 May 2012 02:10 #52 by Ex-Member
well i need to sort out a watt meter still (so much to buy, so little money)
wing and fuselage section.
need to finish planking and then sort out the mounting points.
  • Seamus O Leprosy
  • Premium Member
  • Premium Member
24 May 2012 02:59 #53 by Seamus O Leprosy
26 May 2012 20:06 #54 by Ex-Member
3 days later i am finally back to doing some building.
trying to finish the planking round the main wing and hopefully sheet the top of the wing.
then i can mark out the ailerons and cut them out.
this is providing i have enough 1/16 balsa left to do the wing sheeting, otherwise i will carve the nose and finish the cockpit window and roof area. not having see through windows, will just paint them black.
26 May 2012 23:12 #55 by Ex-Member
cockpit windows have been sheeted and need sanding.
main wing partially sheeted.
wing mounts boxed in.
out of wood now, so the build will have to go on hold till i can afford some more.:(
best dig out the Lanc then.:)
29 May 2012 02:44 #56 by Ex-Member
well i have done a little bit more to the fuselage.
nose cone carved and cockpit windows and roof shaped.
31 May 2012 00:01 #57 by Ex-Member
its the ugly one.
31 May 2012 01:14 #58 by Quorneng
Replied by Quorneng on topic Re: Vickers Viscount
Very nice but those wings look ever so small!
31 May 2012 01:19 #59 by Ex-Member
going to be interesting isn't it.
31 May 2012 02:23 #60 by Ex-Member
how about one as a slope soarer. :P
will need some decals for this one later, once i have decided on what livery and black squares for the windows.
Time to create page: 0.602 seconds
