Vickers Viscount
12 Sep 2012 22:37 #121 by Ex-Member
Replied by Ex-Member on topic Re: Vickers Viscount
right you orrible lot.
i have blended the inner nacelles into the wing.
need sanding yet.
Cut the first aileron out of the wing and built it up and fitted it back.
Can do the other one tomorrow now.
13 Sep 2012 11:16 #122 by The Beard
Replied by The Beard on topic Re: Vickers Viscount
Your using 4 ESC and 2 batteries arent you Tony and you have to cut 1 wire on one ESC dont you.I did that on a short extension instead of the ESC wiring.
14 Sep 2012 01:31 #123 by Ex-Member
still plodding on with the wing.
14 Sep 2012 12:10 #124 by The Beard
Yes but there as an awful lot to this particular wing.Would it originally have had 4 IC engines Tony
14 Sep 2012 12:50 #125 by Ex-Member
4 ic engines and no retracts or ailerons. :P
14 Sep 2012 13:09 #126 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Vickers Viscount
The Beard wrote: Your using 4 ESC and 2 batteries arent you Tony and you have to cut 1 wire on one ESC dont you.I did that on a short extension instead of the ESC wiring.
I use a very small screwdriver to push down the locking tab in the connector, then pull the connector out of the plastic holder. Fold the wire back and then tape it. That way you can always return it to normal when you use the ESC for something else.:)
14 Sep 2012 20:46 #127 by Ex-Member
ailerons covered, wing top covered.
15 Sep 2012 13:39 #128 by Ex-Member
well i can do a little bit more for now, but it will have to stop very soon as i have no funds to buy the wire needed to finish of the motors.:(
going to bend up some fixed main u/c legs and fit them today (just not enough room for retracts and more servo's and no money to buy them anyway)
will go back to the Lancasters as i don't need any money for that one at the moment. :)
15 Sep 2012 17:12 #129 by Ex-Member
trying to sort the wing to fuselage fairing today, needs to stay with the wing as it comes off for storage. :huh:
fiddly, stressful and :huh: time consuming.:unsure:
15 Sep 2012 22:51 #130 by Ex-Member
done the wing to fuselage fairing.
Slopped a coat of red on the wing top.
16 Sep 2012 01:33 #131 by Ex-Member
BEA on the tail needs re doing as do the cockpit windows.
17 Sep 2012 10:06 #132 by Ex-Member
its 5 am unable to sleep due to worries.
slopped some paint on the lower fuselage.
17 Sep 2012 22:33 #133 by Ex-Member
been trying all day to fit retracts, there just is not enough room without a full redesign of the wing and nacelles, so fixed u/c it will have to be.
the main leg will be braced back to the second wing spar with a wire brace to help strengthen it to cope with landings.
18 Sep 2012 10:06 #134 by The Beard
I think the presence in the air and the sound 4 props make will all make up for it.
18 Sep 2012 22:51 #135 by Ex-Member
working on the u/c.
Time to create page: 0.548 seconds
