- Thank you received: 690
- Septic
Rudder next
Cheers
Danny
tap - tap.......rivet
- martynk
Try painting the outer lamination with a drop of water to moisten it. I have found that wood will swell and the dings may disappear voluntarily. They *know* when they are not wanted
Martyn
- Septic
Anyway the rudder is also complete, and I have added the combing over the dash.
Hopefully more later
- Septic
- Septic
Soon be time for the wings, I am really looking forward to that bit as I am building the wings using a new technique to me with split ribs, what could possibly go wrong
- Septic
Cheers
Danny
- martynk
Some stupid questions.
1. Is the top photo a carved and sanded block template?
2. What is happening on the second photo?
3. the 3rd photo looks like you are stripping ribs on the inside edge of the curve - I don't think that is possible
4. I understand the 4th photo. Whatever you did worked and it looks very neat. Cracking plan as well
Sorry about that. I need to know as I may be doing something similar soon
Martyn
- Septic
the block is maple, though it could be any wood, its just I have some maple kicking about. It simply has the rib upper profile on one surface and the lower rib profile on the opposite surface. It was then bandsawed and drum sanded. As it happens the curve on the lower rib leading edge is not significant and can be sanded into straight 1/16th dtrips, so they wont get formed.
The second photo shows the block wrapped in clear parcel tape. Then has two laminations of watered pva taped to it. Once dry these form a nice curved sheet.
The third picture shows I am stripping the curved sheet into 1/16th wide strips, the ones already cut have toppled over onto their side, does that make sense?
As you say the 4th is fairly obvious
Cheers
Danny
as usual another master class from the second main man.
- Septic
The wing has actually gone together quite well, not sure what is going on at the tips yet, but that will sort itself out I am sure.
The leading edge of the full size cub wing is sheeted in alloy, I am going to use paper. Sounds like it could be fun
Did you mean balsa soaked in diluted pva?
- Septic
Cheers
Danny
- martynk
One of the problems I found using paper is that when you apply tissue and dope it has a very different colour density and finish as the (cartridge) paper I used was less absorbent to dope. It will be interesting to see how you get on.
Good luck
Martyn
- Septic
I was toying with printing the reg etc onto the tissue but I will make stencils, as I am comfortable with that route.
Cheers
Danny
- martynk
Septic wrote: Hi Martin, there is no such thing as a stupid question my friend
glad somebody is curious
Cheers
Danny
Thanks Danny
Photo 1&2 - That surprised me slightly. When I was building indoor duration models, the ribs were sliced using a template in a traditional panner from very light 1/64 balsa, not sliced from a warped piece of sheet. Your requirement is different and your ribs are supported by the main spar so will be prevented from straightening
The 3rd photo - I can see that now - at first glance the sheet looked like it was on its side as I was expecting the slices to be cut from a template. Your method makes it look very easy..
Brilliant
Martyn
