South Africa holiday diary
10 Dec 2025 20:01 #46 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic South Africa holiday diary
Or seeing as i dont need many clothes and stuff i could make another smaller box for the glider and the fun fly and put all my personal items in that
That way i still only have 2 check in baggage, it will be a lot smaller
Think i might do that
11 Dec 2025 17:19 #47 by THE BLACKBIRD
Well that did not come out to good, the low tack masking dont like halfords spray paint lifting of the surface
Think iv got all the bits in the box with a sheet of card over the top
Now ill fold the sides down
To lower the height. ill make a 2x1 frame around the top to give it a bit of strength
Its big and awkward to handle so ill come up with a couple of handles, and it feels heavy
12 Dec 2025 13:59 #48 by THE BLACKBIRD
Decided against building another box as the cost will be almost as much as this one, never realised cardboard was that expensive
12 Dec 2025 18:59 - 12 Dec 2025 19:03 #49 by Eric
Replied by Eric on topic South Africa holiday diary
Reminds me of a long time ago, when I was in the R.N.. I'd gone home on a week's leave, to find that my parents were planning on moving house! (They/she hadn't told me beforehand!)
What to do with my models and radio gear?
They wouldn't promise to look after and take care of them - so I bought a load of ply and timber, and made two boxes that they would all fit into, with external frames to act as handles - and packed everything in, screwed the lids down, and crossed all extremities.
They moved house.
About 8 months later, I got leave again, and went to the new house. When I'd found it, I got the usual greeting - "Oh it's you, when do you go back. Sit down and shut up, Coronation street is starting". Dad was at work, of course!
Next day, I found where they'd put my model boxes - down at the bottom of the garden - outside. When I'd shifted stuff around to get to them, I found they'd been thrown or dumped from a great height, this way up signs ignored, the ply and frames had all split, and everything inside was soaked and ruined.
I might just as well have just chucked them into the bin in the first place, and saved myself the expense and work of making the boxes.
I didn't go 'home' again until I left the R.N., and got onto the housing register ASAP. I had to live with them in a tiny room for about six months, before I was offered a council flat, which I grabbed!
Last edit: 12 Dec 2025 19:03 by Eric. Reason: added a comment
14 Dec 2025 19:54 - 14 Dec 2025 20:01 #50 by THE BLACKBIRD
Wow that was bad Eric, my dad never did like me as he had to marry my mother because of me  he would never speak well of me be i never got treated like you
got some wood this morning and made the frame for the top of the box
Had to make an adjustment to the lid in one corner
So almost there with it, just got to fit the handles and add stuffing between the model and the frame
Last edit: 14 Dec 2025 20:01 by THE BLACKBIRD.
15 Dec 2025 11:32 #51 by Quorneng
Replied by Quorneng on topic South Africa holiday diary
That looks very neat.
I only hope for your sake they take due notice of the word FRAGILE.
I suspect the biggest risk is what are the objects either side of it when it is on the conveyor.
15 Dec 2025 12:43 #52 by Klipkopwildlife
Replied by Klipkopwildlife on topic South Africa holiday diary
The airlines treat 'special needs' baggage differently, they don't put it on the conveyors.At the final destination you don't find it on the carousel, it's dumped over in a corner where no one can find it! Ask me how I know! The first time it took me an hour to find it after waiting for the carousel to empty!
Thanks: Eric, THE BLACKBIRD
15 Dec 2025 14:23 #53 by THE BLACKBIRD
Simon where anything is near the sides there is a piece of dense foam between it and the side
I have every time i flew back to Cyprus used the special luggage thingy and have always had to go to a different place to collect it after getting my case from the luggage round about
Still thinking whether to use the helper service at the SA end as the big buck box will be awkward to handle with a case or another box as well, may as well let them push me in a wheelchair and let them struggle with the boxes
15 Dec 2025 15:19 - 15 Dec 2025 15:20 #54 by Eric
Take a tip from the Chinese ARTF industry, and use loads of sticky tape - put each component into it's own plastic bag, then tape each plastic bag VERY thoroughly to the box and/or each other, making the contents one solid lump that cannot shift or bash about.
Last edit: 15 Dec 2025 15:20 by Eric. Reason: typo
15 Dec 2025 17:38 #55 by THE BLACKBIRD
Been to thee docs and had another jab in the shoulder, hope that will kill it down a bit
Made 8 6mm ply plates to go inside and outside the box glued and stapled to the top frame and cardboard
For the rope handles to go through
I put a sheet of card on the top
Then the lid
Recon thats about it, just got to weigh it now
15 Dec 2025 18:46 #56 by Quorneng
I would think a "helper" at the airport is a very good idea.
I am not sure I would like to manage that box as well as any luggage.
I managed to collapse whilst dragging just one case onto a ferry going to the isle of Muck!
16 Dec 2025 16:22 #57 by THE BLACKBIRD
I weighed the box today, rigged it up so i could lift it
And its come out at 14.42Kg not heavy but bloody awkward to handle
16 Dec 2025 17:48 #58 by Klipkopwildlife
At the SA end you could wait a very long time at Passport control, Landside assistance takes you straight through the Crew control. Once you have your baggage it's about 50 metres to the arrivals rotunda, I'll be waiting just outside the sliding doors.
Thanks: Flytilbroke, THE BLACKBIRD
17 Dec 2025 18:07 #59 by THE BLACKBIRD
Found some more bits to go in the box
21 Dec 2025 16:52 #60 by Klipkopwildlife
1 month to takeoff Tony!
Time to create page: 0.606 seconds
