This 'after body' cone will be suspended in this part of the duct to keep a constant cross section area as it changes from an annulus as it leaves the EDF to the circular duct.
The test duct with the EDF in place.
The tube of UHU gives some idea of its size.
This 'scrap' duct is being built to test the method of construction and is about a far as it need go.
An exact fully clad and working Canberra duct is next.
love the way you work this stuff.
So the larger wooden mandrel had to be re-machined to a slightly shallower taper and the front section of the duct rebuilt.
The really fun bit will be suspending the after body in the duct on 3 tiny litho fins and it will have to be done after the planking is complete and the mandrel removed.
Just as an aside formers 3 & 4 (from the left) are quite substantial and coincide to the position of the wing 'D' box so should be able to handle the loads.
The after body installed in the duct.
The after body looking up the rear of the duct.
The nacelle weighs 10.4g
I was hoping to show the EDF installed but the one I selected doesn't work! :woohoo:
The other does but by then it was getting late.
how do you do it.
I was about to order a replacement 30mm EDF from HK but I then noticed the current version is slightly different. It has a 9000kV motor instead of the 10200kV on the only 'good' one I have.
This means they are likely to have slightly different levels of thrust.
With such a light plane and the nacelles being quite far out along the wing I dare not risk 'odd' EDFs so I am faced with having to buy a new pair of EDFs which is a bit daft as the only reason I selected the Canberra in the first place was to 'use up' the two that I already had! :woohoo:
I now have to decide whether to buy 2 and continue as planned or stop the Canberra build altogether and just do comparison tests with the one EDF I have to determine how much thrust is lost in the nacelle for the benefit of some future build.
I for one, dont want to see this thread end, so , has anyone got one of these EDF s knocking about doing nothing that can be donated to Q to continue this build ???? Over to you folks
Alan many thanks - one ordered.
Lets hope when it comes (January
The thrust given is way more than the spec for the HK version - like twice as much and 3 times the current! :woohoo:
well done though sir.
All Depron with tissue covered panels aft of the D box. The tail surfaces will be singe sheet Depron with an inset balsa spar. Like the nacelles the fuselage will be all planked.
With a total of 4 oz thrust I have a bit more weight to play with but with a 14A draw the battery will have to be bigger too. Ideally I would like a 1300mAh 2s to keep close to a 10C (6 minute) flight duration but a 950mAh Nano-tech 25-50c at 1.6 oz looks more likely.
