19 Jun 2022 10:42 #316 by THE BLACKBIRD
I only used balsa, 6mm x 6mm spruce, 2mm light ply and 3mm light ply, a piece of 12mm ply for the fire wall, i did use some .4mm ply for the leading edge of the wing but i dont recommend it, took a bit of wrapping around the ribs
i also used some pro-skin for the front of the fuselage and i have some of that you can have
Now if your going to build one how about doing what i did when i left Cyprus, i scrapped the fuselage except for the front section which i did not build to the plan as i wanted it better and stronger and all you need to build is the rear fuselage as the tail,fin and wings are ok
It would certainly reduce the size of the box needed as it flat packed nicely
21 Jun 2022 17:53 #317 by Klipkopwildlife
What size would the container be if you did as you propose?
21 Jun 2022 19:28 #318 by Eric
A 20 footer should do!
22 Jun 2022 18:23 #319 by THE BLACKBIRD
I would think 1m long 500 wide 500 high
Time to create page: 0.794 seconds
