Precedent T180 Restoration
- squareflux
- Thank you received: 328
I have an idea in my head of the colour scheme, but I'll probably just wing it a bit as I go.
I need to sand all the surfaces first though. The tail I practiced on is pretty rough, and every tiny bump and mark shows through.
Sanding sealer helps but that's adding weight.
After you have thoroughly sanded the frame, give it a GOOD dusting, then wipe over it with a wet sponge!
Let it dry, then feel it, you'll be surprised how rough it is! The water allows all the loose fibre ends to stand up (no rude comments, thanks!), then you can sand it again with a very fine paper,, wet it again, and so on, until you get it as smooth as possible.
- squareflux
Anyway, I got a cold food delivery today, and the insulation packing is made of sheep's wool in a plastic bag. It's a pretty thick sheet, probably 10-15mm, and compresses. It seems like it'd be ideal for the job.
Any downsides you could think of?
- squareflux
- squareflux
- squareflux
I'm going to make a magnetic hatch in the panel in front of the windscreen so I can see the tank when refuelling, as it'll be hidden from inside once the dash is in place.
- squareflux
I wasn't expecting this till later in the week, so it was nice getting it today. It's a bit of a lump compared to the SC 46. But now when I look at the engine mount that was on the T180, I realise it was probably fitted with a 50 or 60 size engine, as the 46 mount is much smaller.
It's all starting to come together now. I'll get the rest of the covering I need tomorrow, and some other bits should arrive as well. Depending on how things go, I could have it finished in a week. Just in time for the end of summer :lol:
- squareflux
Recommended props are 11x8, 11x9, 12x7, 12x8. I think I'll go with a 12x7.
I know what the pitch and diameter numbers of the prop mean. But what difference does the prop size and pitch make to the engine?
I've got an 11x7 that I was going to use, but it's not one of the recommended sizes.
