SR71 BUILD - The Blackbird.
- Grumpy42
- Thank you received: 10842
The weight is still unknown but im looking to get a minimum of 10kg hopefuly up to 14kg from the fans on 12s each, the fans according to people that have got them give 7kg each, and i have fitted Scorpion motors .
I hope it comes in at around 15-17lbs
Then again i have never built anything like this before, im new to the leccy stuff and have been away from model aircraft for the best part of my life.
am on a learning curve, a very steep one, lol
Cracking build but will not the engine 'spikes' seriously reduce the inlet area or are they removable?
The principle I have used is to leave the air leaving the fan strictly alone.
A lot of energy has been used to speed it up and almost anything tends to slow it down.
The inlet the air stream has a fairly constant velocity across the width of the duct but aft of the fan it is not, being fastest from the tip region of the fan and slowest from the root. Hence the benefit of really smooth outlet ducting with little or no change in direction.
Is that 12S LiPo - 44.4V?
thats the bloody esc's i have, they came from giant cod, and today giant cod tell me they are no good for the motors im useing, i also programed them in.
@£84 each
I want to get it right this time opinions please
Tried to donwload the artical and put on here, but my computer skills are wanting
Black Mantis 120amp OPTO esc Speed Controller High Voltage Specifications:
120amp OPTO Speed Controller
Nixx: 18-38NC
Lipo: 6-12
Weight: 149g
Bec Output: No
Dimension (W*L*H) : 34*52*20mm
Programmable: YES
Features:
Extremely low internal resistance
Super smooth and accurate throttle linearity for better flying experience
Saftey thermal over-load protection to save problems occurring
Auto throttle shut down in signal loss situation
Supports high RPM motors
New Advanced programming software
note MAX battery is 12 cell lipo.
