TOP FLIGHT MUSTANG
21 Nov 2012 05:02 #16 by Ex-Member
Replied by Ex-Member on topic Re: TOP FLIGHT MUSTANG
Not looked at this for a while.
well i have looked at it, every day in fact as it is right next to my building table.
but just not got round to doing anything.
22 Nov 2012 17:24 #17 by Phil Wood
Replied by Phil Wood on topic Re: TOP FLIGHT MUSTANG
There's an awful lot of sheet balsa on this one Tony, any idea how the weight is holding up?
I can imagine it'll need a fair bit of poke, but have you any idea what the all up weight will be?
Pol,
22 Nov 2012 18:33 #18 by Ex-Member
hi pol
it is supposed to weigh about 8lbs all up.
so a big motor will be needed.
05 Dec 2012 00:03 #19 by Ex-Member
right decided to do a bit more. (i need to clear all the back log of builds)
cut out one flap, finished sheeting it and did the hinges.
first time using robart hinges.
thats full down at 1.75 inches.
aileron on that side next, then we can do flap and aileron on the other side.
05 Dec 2012 20:15 #20 by Ex-Member
well i have sorted one aileron out this morning. :cheer:
doing some more to the twin as well.
back on the stang wing later today, will try to get the other flap cut out and sheeted.
06 Dec 2012 01:50 #21 by Ex-Member
06 Dec 2012 23:05 #22 by Ex-Member
we now have 2 flaps :cheer:
Both ailerons sorted and the wing tips shaped and sanded.
wing back on to check flap fit against the wing fairing.
next we have to take the wing off agian and fit the flap servo's and decide about retracts.
though they will have to go on hold until i have the funds, so i will go back to the fuselage and sort out battery trays and cockpit details.
07 Dec 2012 19:05 #23 by Ex-Member
built a vertical battery box that sits behind the fire wall, it will take 3 x 3s batteries or a couple of 4s depending on what motor and power requirements will be needed.
need to make a slide in box for the rx next, then i can look at the cockpit area.
08 Dec 2012 09:37 #24 by Phil Wood
Are those flaps scale Tony .... they look bl**dy huge? :woohoo:
I'd hate to switch then in when coming in to land .... probably go vertical !!!!! :woohoo:
08 Dec 2012 15:50 #25 by Ex-Member
yup its all scale pol.
want to put more detail in on this one, need to push myself to improve on my build skills and learn more tricks.
so we are going for a full cockpit and pilot on this one and maybe even rivet detail( though that might be a step too far)
08 Dec 2012 21:40 #26 by Ex-Member
battery box in place.
gun ports in place, i need to blend these into the wing before covering.
Now not in the original kit, but fitted to the real thing is the outlet for the radiator scoop.
this gave an extra 4 top 5 mph when open.
09 Dec 2012 18:21 - 09 Dec 2012 18:26 #27 by Ex-Member
Cut and sanded the exhausts.
filled the bottom of the nose molding where it was cut for an ic engine.
cut the air intake to help cool the motor and esc.
drilled the vent holes, 25 each side. these were vent panels on the full size as well, though they could be covered in cold weather.
just need to do the final sanding on the fuselage and i can start covering it.
Last edit: 09 Dec 2012 18:26 by Ex-Member.
09 Dec 2012 19:24 #28 by Eric
Replied by Eric on topic Re: TOP FLIGHT MUSTANG
It looks like a Merlin powered Mustang, then, not the Franklin one!
I hope you are providing more air outlet than these 50 drill-holes, but no doubt you've thought of that!
09 Dec 2012 20:52 #29 by Ex-Member
there is another outlet under the nose to be cut out yet.
not that it will ever get finished.
no money to buy the motor/batteries needed.
09 Dec 2012 23:18 #30 by Ex-Member
last outlet done.
Ariel done and just pushed in for now.
just need to finish the wing fairings and i can cover the fuselage. :)
Time to create page: 1.262 seconds
