TOP FLIGHT MUSTANG
18 Dec 2012 18:29 #46 by Ex-Member
Replied by Ex-Member on topic Re: TOP FLIGHT MUSTANG
Back to more squinting and trying to keep my hand steady while painting the invasion stripes.
got the white middle stripe still to do.
Mid tank fuel cap stuck on.
cockpit going in.
Got the stripes on the other side to do yet, but should be ready for final sealing tomorrow.
18 Dec 2012 22:00 #47 by Ex-Member
Back to shaky hands and squinting.
still i have the first coat of white on.:)
Covering the elevators now, then they can be fitted and painted to match.
then, then, then we can do final sealing of the fuselage and jobs done.
18 Dec 2012 23:50 #48 by Ex-Member
White has had its second coat now.
once dry i can then seal the surface with 3 more coats of polyc.
then we can finish and fit the elevators.
19 Dec 2012 00:27 #49 by Garry Pollard
Replied by Garry Pollard on topic Re: TOP FLIGHT MUSTANG
Tony B. AKA Blooper wrote: Back to shaky hands and squinting.
20 Dec 2012 19:29 #50 by Ex-Member
Elevators are painted and now drying, then we can glue and hinge them on and seal.
Flaps and ailerons are covered now, need 2 more coats of sealer and we can paint them.
Doing the flap servo mounts at the moment.
Then thats it till after Christmas.
need to order retracts, oleo legs and wheels and we can finish the wing.
Back on the Lancaster in January.
20 Dec 2012 20:44 #51 by Ex-Member
Flap servo's
Various bits drying in the sun ( HA)
17 Jan 2013 23:01 #52 by Ex-Member
Replied by Ex-Member on topic TOP FLIGHT MUSTANG
oleo legs turned up from china today.
ordered 2 sets, so i have a set ready for the sea fury build.
18 Jan 2013 17:24 #53 by Mossie
Replied by Mossie on topic TOP FLIGHT MUSTANG
Hi Tony, I built one of these last year, (yours looks good) i went for the Ferocious Frankie colours,i fitted an os 120 lump up front and it flies like a dream.
02 Feb 2013 01:02 #54 by Ex-Member
well i was waiting for paint to dry so i dug this out again.
glued the elevators on and screwed the canopy on.
then we got the wing out and took a look at the ailerons, well after lots of fafing about i got them working, but in the end decided the bellcranks and center servo was just not working right.
so i have cut big holes in the wing and removed all the gubbings, going to retro fit servo's in the wing for the ailerons.
flap servo's fit ok and work.
then i cut a hole in the wing for the first retract unit.
works, but the oleo leg is a bit too thick and jams the retract unit shut, so i will need to file a flat on the top of the leg for clearance.
need some 4inch wheels next so i can sort out the wheel wells.
we are getting there with this one.
i recon two weeks will see it all done.
02 Feb 2013 22:06 #55 by Ex-Member
well today i had to cut holes in the wing to run the aileron servo wires and make servo hatches.
then i fitted the ailerons.
after that we did some more to the retracts.
needs bigger wheels and a tail wheel, but you get the idea.
bit stuck now until the wheels and servo's turn up.
i can fit the flaps next though.
02 Feb 2013 22:12 #56 by alan cantwell
Replied by alan cantwell on topic TOP FLIGHT MUSTANG
MMMMM pretty, i flew one of these a few years ago, with an ST91 motor, it flew superbly, no vices at all, have you managed to find a mustang spinner yet, what diam is it?
02 Feb 2013 22:25 #57 by Ex-Member
not looked for a spinner yet.
will probably fit a 3 blade prop when it is finished.
shame it is not mine though. :(
02 Feb 2013 22:53 #58 by Garry Pollard
Replied by Garry Pollard on topic TOP FLIGHT MUSTANG
Wonder who this one is for :woohoo: :woohoo: :evil: :evil:
03 Feb 2013 01:13 #59 by Ex-Member
tried the flaps in place.
a bit tight,the sealer on the edges has made them a touch wide.
have to sand it back a touch before i fit them tomorrow.
03 Feb 2013 06:29 #60 by The Beard
Replied by The Beard on topic TOP FLIGHT MUSTANG
Another stunning model your expert creativiy has produced Tony very impressive I must say.
Time to create page: 1.902 seconds
