- Thank you received: 690
- Septic
Cheers
Danny
tap - tap.......rivet
- Septic
Here are the bounding boxes as promised, these are the extremities remember. I now have to make the cut through sections fit inside the boxes and extrapolate or "loft" the ones in between. All good fun....
Cheers
Danny
- Septic
That looks very nice.
I just cannot resist detail - I must suffer from OCD!
This pic seems to suggest the rear fuselage structure is braced slightly differently with what I believe is called a "Sub divided Warren truss".
Also interesting is that the "formers" of the top half of the fuselage are clearly not load bearing in any way as their positions do not correspond to the bracing points of the structure underneath! :ohmy:
In many respect Auster's take on the fuselage design is a bit more logical given they both originated from the Taylorcraft.
That way it completes the zig-zag stress transfer pattern, and also extends the cabin upper brace loads to the lower stringer.
- Septic
- Septic
Hope so because I have started putting the fuselage together, building with 1/16 square is proving challenging to say the least!
Cheers
Danny
- martynk
- Premium Member
Martyn
- Septic
We shall see
- martynk
- Premium Member
Martyn
1. Pre-shrink the tissue and iron it before attaching it to the model, or
2. Shrink with a light touch of steam. Repeat as necessary until the required shrinkage has been achieved, or
3. Use meths as a shrinking solution rather than water.
...and as Septic so rightly says, use banana oil to finish the tissue, which is simply a non-shrinking dope with added plasticiser. If banana oil is not available, then non-shrinking dope with a few drops of medicinal caster oil works just as well.
- Septic
First of all my carbon rod arrived, this is 0.28mm, 0.5mm and 0.7mm. I already have some 1mm but that would be too heavy for this......
Cheers
Danny
- Septic
Cheers
Danny
Where are going to use carbon rod?
