Big Bobber
- Away
The Wanna play and the Fearless are on hold since I don't expect the FunCub to last much longer.
Obviously one of Rene's early creations since it doesn't use LW-PLA, just regular PLA although I've used PetG
A hiccup in Cura meant that the 2.5mm tongues on the end of each wing panel didn't get printed so I made a plan by gluing in pieces of CF to form locators at the end of each panel.
One of the things that does surprise me is how good the glue bond is using CA, I can crush the wings but I can't break them!
The amount of internal detail in the wings is remarkable
- Away
The flaps are bottom hinged.
And now complete
Now to start the fuselage.
That's backwards!
Ailerons are usually top-hinged, to keep the profile as smooth as possible in the faster moving air going over the top, while flaps are bottom-hinged, so when raised, again the profile is pretty clean, but you can get a 90' deflection if you want - without a huge gap underneath when they are raised!
- Away
Note how the Flap servos are reversed so that you can use a 'Y' lead if you want.
You want both your flap servos in the same orientation, and the aileron servos in opposition!
ie both output disks facing (say) north for the flaps, and one facing north and one facing south for the ailerons, again if you use a Y, not two rx outputs on different channels, and a tx mixer.
Although not relevent here, the fun starts when you try to operate rudders and elevators on a Vee-tail model! (Yes I know Taranis - and possibly others - has that mix pre-installed!)
- Away
265gms and 269gms, but one is missing its tip light, not that it'll make much difference.
The rear frame is a nightmare to get square, exacerbated by the fact that the PLA is very slippery!
How much is it expected to weight.
- Away
AUW is supposed to be 1.5kgs, I think it's going to be more.
I put the wings on to help
The rear fuselage feels pretty robust, how it'll fair in a crash is anyones guess
- Away
Interesting that my battery is further back that their pictures.
After spending over an hour cutting out the wind shield I promptly lost it!, It finally surfaced out of the worm hole this morning when I walked in to my cave.
All ready to go, just waiting for the right day.
- jon.in.swansea
- Thank you received: 1192
Hope that landing gear has lots of spring to it - thinking of your field of dead grass clumps.
- Away
Surprisingly the Bobber has a shorter wings span than the Cub by 15mm
However the Cubs chord is only 220mm where the Bobber is 235mm
The Bobber has around 5% more wing area but is quite a bit heavier than the Cub.1.46kg to 1.15kg
- Away
The rear, stick, fuselage of the Bobber is MPLA, it's supposed to be 5 x stronger than PLA. I've only now started to strip the Bobber, very little is recoverable although most of the stick fuselage and tail is largely undamaged, I noticed this morning that the lower, Port, longeron is broken where it meets the main body, given that she came down belly first, you would expect the top longeron to break, if the breakage occurred on take off, remembering that my strip is anything but smooth, the decalage would be constantly changing with elevator input and the rudder would move as well, precisely the kind of control problems I was getting! Isn't hindsight wonderful!
