- Thank you received: 1192
Big Bobber
- jon.in.swansea
15 Jan 2025 09:19 #46
by jon.in.swansea
Replied by jon.in.swansea on topic Big Bobber
I found a fellow discussing a inexpensive film covering for his balsa models. He also uses it as a base layer to put 'aged' tissue over.
Essentially it is a refill role for machines that do laminating of documents/posters. It is translucent until heated. Has adhesive for attachment via iron and will shrink if hit with a heat gun. Seems to come in two thickness ranges. He got ~100m x 300mm roll for 20 quid. Video on how to use laminating film on a wing:
- jon.in.swansea
15 Jan 2025 17:44 #47
by jon.in.swansea
The scale of the wing half show up via the empty printer spool in the lower left corner!
So if enough folk asked I wonder if they would re-design the bobber wing structure to use a mix of PLA and LW-PLA?
16 Jan 2025 07:48 #48
Replied by Eric on topic Big Bobber
Depending on the weather conditions, I have enough difficulty seeing my models when they are flying, never mind having a see-through one! The ultimate in 'stealth' aircraft!
Time to create page: 0.481 seconds
