- Thank you received: 328
Precedent T180 Restoration
- squareflux
I'm going to have to think of the colour scheme though.
I was testing fitting the servos and control rods yesterday, and I need to build a raised servo tray. So that'll need done first.
- squareflux
I'm going to change the control linkages though. I'm also going to ditch the inner snakes and change them to rods. I inserted shorter threaded rods into the snakes, but there's some resistance.
I take it there's no issue if the rods aren't the same inner diameter as the snake outers? I was going to use 2mm or 3mm rods.
I need to then work on the fuel tank plumbing. Any tips for securing the tank in the nose?
- Thank you received: 14473
Fuel tank - don't make it permanent! Most people just trap it in with foam rubber, and make sure it can't slide back and to!
Rule of thumb - if you can't get at it, that's the bit that will go wrong! :S
- squareflux
I'm going to need to place some orders before I can progress more.
The other big job I was considering, was cutting out the firewall and making a new one.
I want to mount my engine at 90deg, so the exhaust is straight underneath. I've ordered a pitts style exhaust for the job, and so I don't need to cut holes in the cowl.
But the old engine mount was at about 45deg, so the T-nuts are already in place and I think would interfere if I tried to add new ones.
Then make a doubler to go behind the exising F1, thoroughly epoxy it in, drill through, and bolt through into that.
If the back is inaccessible, you will have to make another cuppa and have a think about it! :evil:
- Flytilbroke
- Thank you received: 1987
- squareflux
I can get to the back of it quite easily, so I'll remove the nuts, and put in a doubler as suggested.
- squareflux
I had a question about sticking covering over covering. I was going to do the central span of the wing blue to match in with the fuselage. Can covering be tacked over other covering, or would I be better leaving a gap when doing the top of the wings? Also does covering stick to the fibreglass ok, or does it need any prep first?
In the meantime, and for curiosity sake, I calculated the CG using a couple of calculators and they're both showing in the same range. The range covered puts the CG point just in front of, or on, the main spar.
www.ecalc.ch/cgcalc.php?deeplink=Precede...0;0;0;0;72.5;25;12.5 ;
You better of painting the cowl tbh, pin stripes are good fun, you do need a steady hand though.
You can overlap film, but not too much, or you will, as stated, start to get bubbles - but you can pop them by sticking a pin into it, then chasing the air out from edges to centre (or pin-hole!)
You'd be better painting glassfibre, as film doesn't stick very well. If it's the glass in the centre join, then cover that bit first, and the overlaps on the wood parts will help to hold the film on, and keep the oil out.
I remind you of my earlier post about keeping all the joins downwind!
- squareflux
I'm going to cut it off and practice again, but I'll practice the cuts on tracing paper first.
Again, this is all new to me. I don't think I've done bad for a first attempt, but I don't want to make a mess when I'm doing it for real.
Much of the quality of the covering is to make it look good. Small imperfections will make absolutely no difference as to how it flies. Of more concern is to avoid ironing in any warps as they will make a big difference.:woohoo:
