Precedent T180 Restoration
- squareflux
- Thank you received: 328
To be honest, I'd never seen snakes till I got this model and it had them. I suppose I could just have used rods, and I suppose I could still using the outer as a runner, before I finalise the controls.
- Thank you received: 14473
I prefer the braided wire inners in the nylon outer, for strength - those star-shaped plastic ones can buckle if the adaptor screw-thread isn't almost all the way to the stiffer outer tube. Once it has buckled, you may as well discard it, or cut the bad end off and use it somewhere with a shorter run.
- squareflux
I had to get the outers done now though before I put the top plate of the fuselage end back on.
Then firmly trap the inner and outer together, at one end, and just the outer at the other, and push and pull on the 'loose' inner. You will be surprised/horrified just how far it can move, as it takes up the slack caused by the minimalist clearance!
Fine if the outer is roughly straight down the fuselage but if you have a lot of excess that's unsupported, the excess moves when you move the control surface against the non moving servo allowing free movement on the control surface.
Anyway that won't be a problem here, those outers are as straight as they can be. The crossover inside the fuselage is standard operating practice.
- squareflux
Just need to glue it all on now.
- squareflux
Thanks to all of you for your help and encouragement. I'm sure I'll have a ton more questions before I'm done.
p.s. none of this is glued yet, it's just test fitted.
- squareflux
Anyway, I suppose I need to start thinking about covering as I need to complete that before glueing the hinges and fixing the control surface and rods.
The local hobby shop says they could get me oracover, but having never done any covering, I've no idea. I'll need to get an iron as well.
They also can get easycoat, which is oracover seconds, in longer rolls.
Any advice?
Take a look at the website, if there's anything you fancy give me a shout, I get staff discount so I could buy it and send it on ( that applys to all you guys btw).
covering does take a bit of practice, make yourself a test frame and practice on that..
- squareflux
I'm not sure about colours. I was thinking red with white stripes on top of the wing.
But I was looking earlier and saw some with a few different colours. So I'll need to have a think.
I've got the old tail that I can use to practice on.
Think of how the air flows over the surface, when in flight, and place all your seams and joins downwind, or exhaust oil can be forced underneath, and once oily, nothing will stick back down!.
There's a how-to on here, somewhere.
After a lot of hunting - found it! -
www.aeromodellers.co.uk/forum/constructi...-cover-a-model#12488
Before I had a heat gun, I would turn the iron up to maximum and use the radiated heat to shrink the covering.
