Trent Meteor for 2015 start.
03 Jan 2015 20:03 - 03 Jan 2015 20:28 #91 by Ex-Member
Replied by Ex-Member on topic Trent Meteor for 2015 start.
Gave it a second coat of diluted pva this morning and left to dry.
then slopped a skim of filler over the joins in the paper and when dry sanded the nose smooth.
can't do anything more now till the depron turns up. :( :(
Last edit: 03 Jan 2015 20:28 by .
03 Jan 2015 21:56 #92 by Ex-Member
Well i did some rivets out of interest to see how they would turn out.
not too bad i think.
03 Jan 2015 22:25 #93 by alan cantwell
Replied by alan cantwell on topic Trent Meteor for 2015 start.
Its 2015 Tony, you can start it now, :P
04 Jan 2015 15:37 #94 by Ex-Member
been riveting the other side of the nose today.
no pics cos it is boring.
05 Jan 2015 14:12 - 05 Jan 2015 14:21 #95 by Ex-Member
i was worried that the rivets would not show and that i had wasted my time doing them all, so i slopped some paint on the nose just to see if they looked ok.
not brilliant, but better than on the hurricane.
few issues with the brown paper joins, but still better than the TSR2 covering.
one day i will get it spot on, maybe the next model. :P
Last edit: 05 Jan 2015 14:21 by Ex-Member.
05 Jan 2015 16:01 #96 by Quorneng
Replied by Quorneng on topic Trent Meteor for 2015 start.
Very neat but I thought the Meteor 'flush' riveted! ;)
05 Jan 2015 16:33 #97 by Ex-Member
well this one ain't.
:P :P :P :P :P
its not a scale model and it looks nice with domed rivets. so ner. :P :P :P :P :P
06 Jan 2015 19:47 #98 by Ex-Member
papered the nose and the front underside today.
filled any gaps in the paper and left to dry.
tomorrow i will sand it all smooth and give another coat of pva, then i can mark it up and do more rivets.
16 Jan 2015 13:39 #99 by Ex-Member
Had ten days break from this while i worked on getting the stearman ready for flying, but as i am now awaiting some parts i dug out the depron and made a start again.
sat for ages working out the drawings and marking up the wing centre section cores and then cutting them out.
60 inch span on the centre section :)
working on the main spars now.
16 Jan 2015 16:59 #100 by Ex-Member
Made some composite spars up for the centre section.
Root rib and main spar getting glued in place.
got to sort the ribs and joiners next. :)
17 Jan 2015 17:01 #101 by Ex-Member
cut some front ribs, made holes in them and glued them in.
Then i made the rear composite spars (thanks simon for the idea) and glued them in as well.
thats it for a days work :( :(
17 Jan 2015 17:32 - 17 Jan 2015 17:33 #102 by old fart
Replied by old fart on topic Trent Meteor for 2015 start.
How and why did you put the holes in? :)
Last edit: 17 Jan 2015 17:33 by old fart.
17 Jan 2015 19:10 #103 by Ex-Member
holes are there to save some weight, i will be doing the same to the flat sheet later as well.
i use a sharpened tube to cut the holes.
18 Jan 2015 12:57 #104 by Ex-Member
took a deep breath and cut the outer wing panels.
cut two ply joiners and joined the top of the centre section together, will do the same with the underside when it has been built.
thats a 1ft rule on the wing. :ohmy: :ohmy:
18 Jan 2015 13:04 #105 by alan cantwell
Die hedral? Washout? Impressive, Hope its stiff enough!
Time to create page: 1.066 seconds
