Trent Meteor for 2015 start.
02 Feb 2015 20:31 #136 by Ex-Member
Replied by Ex-Member on topic Trent Meteor for 2015 start.
it was a hard choice to take, but i need to stiffen the rear end up somehow.
i just hope the outer skin will make it solid enough.
03 Feb 2015 13:18 #137 by Ex-Member
Added four 1M length of depron to the rear of the fuselage this morning,
stiffened the rear up no end.
03 Feb 2015 15:44 - 03 Feb 2015 15:54 #138 by Garry Pollard
Replied by Garry Pollard on topic Trent Meteor for 2015 start.
I have an apology to make. How the hell have I missed most of this thread ??? But I have !!. Tony It is enormous . Is it going to be maidened up here ??
Last edit: 03 Feb 2015 15:54 by Garry Pollard.
03 Feb 2015 18:05 #139 by Ex-Member
been sheeting the rear of the fuselage today on and off.
does not twist at all now, so that is good.
03 Feb 2015 19:09 #140 by old fart
Replied by old fart on topic Trent Meteor for 2015 start.
Garry Pollard wrote: I have an apology to make. How the hell have I missed most of this thread ???
Must be an age thing Garry.
05 Feb 2015 13:06 #141 by Ex-Member
well the time has come.
the fuselage is stiff enough.
so.....
gulp
gulp
we stuck the tailplane on for good.
once it has set, i can finish the fin and build the tailplane fairing.
then fit the rudder servo and fit the rudders.
yes two rudders as it spits either side of the tailplane fairing.
so closed loop on the main rudder and the top one will be linked with a torque rod.
started covering the elevators as well.
06 Feb 2015 22:37 #142 by Ex-Member
No pictures from today's work i am afraid, it would be too boring.
all i have done is make up some gussets and a couple more spars to located and fix the tailplane rigidly to the fin
elevators are now fully covered and ready for paint.
servo box for the rudder is made and can be fitted tomorrow.
07 Feb 2015 18:06 #143 by Ex-Member
rudder hinge blocks in place and the rear spar sorted.
thats it. takes ages to do stuff with big models.
08 Feb 2015 17:18 #144 by Ex-Member
well lets have today's work shall we.
both rudders are hinged and temporarily fitted.
started the top of the wing fairing framework.
rudder servo is now in place as well.
09 Feb 2015 17:01 #145 by Ex-Member
Stuck two more long bits of depron onto the fuselage and then started the rear of the tailplane fairing.
then some planking ensued and you end up with this.ng
Needs trimming to length and the cone building tomorrow.
Then it is back to the front section.
09 Feb 2015 22:35 #146 by Quorneng
Replied by Quorneng on topic Trent Meteor for 2015 start.
Big or what!
For a moment I thought you were putting an EDF in the tail :woohoo:
10 Feb 2015 17:56 #147 by Ex-Member
started gluing in the fin ribs.
First coat of paint on the elevators.
here is the tailplane fairing.
Rudders sheeted and the dummy ribs gluing.
Everything pushed in place for a look see.
we plod on slowly.
12 Feb 2015 19:11 #148 by Ex-Member
Had a few issues to sort today.
the rear of the fuselage was too fat, so i had to cut it down a touch, then the tail post had to be straightened up.
then the main fin was slightly twisted.
the bin was beckoning, but i persevered and sorted all the issues.... i hope.
then i painted the rudders.
fitted the tail cone.
then i started the tailplane to fin fairing.
need some long servo leads before i can finish sheeting the fuselage, so it will be wings tomorrow.
13 Feb 2015 00:47 #149 by Quorneng
The fin/tailplane fairing seems to have been altered quite a bit during its life.
Some photos show only the leading edge bullet, some look like your circular one, this one looks like the aft fairing was square!
13 Feb 2015 06:55 #150 by Ex-Member
Thanks for that Simon.
there are many variations of the tailplane cowling, i just picked one and hoped for the best. :P
Time to create page: 1.267 seconds
