Trent Meteor for 2015 start.
13 Feb 2015 17:48 #151 by Ex-Member
Replied by Ex-Member on topic Trent Meteor for 2015 start.
Fin is coming on now.
got some more sheeting on it now, left a hatch for rudder servo access.
Main spars for the outer wing panels made and fitted.
Ailerons cut out and i have started fitting the hinge blocks.
now if i can get an uninterrupted day tomorrow, i hope to get them almost finished.
14 Feb 2015 12:58 #152 by Ex-Member
got a couple of hours in this morning.
more sheeting on the fuselage done.
Then i moved onto the wings.
hinge blocks fitted and i have started making ribs.
Having some lunch and then back to cutting ribs.
14 Feb 2015 16:52 - 14 Feb 2015 16:53 #153 by Ex-Member
Looks like it's coming along nicely Mr B, well done you!
:cheer: :cheer:
Last edit: 14 Feb 2015 16:53 by .
14 Feb 2015 18:41 #154 by Ex-Member
well i managed to get all the ribs cut and fitted to the tops of the outer panels, plus the second spar made and fitted.
15 Feb 2015 13:59 #155 by Ex-Member
well i have done all my chores and the sun was out, so it seemed silly not to.
The FF Fulmar in the front has a 32" wingspan.
15 Feb 2015 15:10 #156 by
Replied by on topic Trent Meteor for 2015 start.
Wow Tony, that is impressive!
16 Feb 2015 18:19 #157 by Ex-Member
Not got much done today, been on taxi service.
i have repaired the damage to the outer wing panel ( remember not to stand on it next time)
and made up the ply tongue for the wing to fuselage join.
thats it. :(
17 Feb 2015 20:32 #158 by Ex-Member
finished the wing tongue today, added some extra ribs where the fuselage meets the wing and started the top sheeting.
18 Feb 2015 19:20 #159 by Ex-Member
Time for today's update.
Been cutting holes and adding sheets to the middle section.
The two middle sheets have not been glued yet.
It started out weighing 780gms and after cutting holes and adding sheets and extra ribs it now weighs 791gms.
19 Feb 2015 17:59 #160 by Ex-Member
back to the long slow job of cutting ribs and holes.
20 Feb 2015 21:12 #161 by Ex-Member
todays effort
wing spars for the outer sections.
one side of the ailerons ribbed (for your pleasure)
More ribs on the centre section, need to sort the flaps and retracts before i can add anymore.
sorting the root rib on the outer panel.
21 Feb 2015 19:45 #162 by Ex-Member
Started the rear spars for the outer panels.
cut some more ribs.
not had a very good day today. :(
22 Feb 2015 19:33 #163 by Ex-Member
rear spars finished and fitted, all the ribs done.
next job is to finish the ailerons and wing tips.
23 Feb 2015 18:31 #164 by Ex-Member
Servo mounts going in.
ailerons nearly sorted.
If i can get an uninterrupted day tomorrow i want to finish the ailerons completely.
23 Feb 2015 18:32 #165 by nit23s
Replied by nit23s on topic Trent Meteor for 2015 start.
Hi, plz upload video of the flight.
Time to create page: 1.212 seconds
